Last night, with granatelli wires and new plugs in hand, commenced a failed effort to get at the installed plugs...their position, deep in the engine bay proved to be an insurmountable challenge for me (just getting at the wires - particurally those towards the rear were a problem).
How the heck are GM and do it yourselfer's pulling off the plug removal's/install's...guessing my wratchet handle may be to short or lack needed articulation to maneuver into the tightest of the locations...
that's because you don't know anything about cars, we have established that long ago.
I have one. it's sort of like this, but not crappy. socket
Then others like you pretend too! Writing with capital letters and periods are not your strong suit either!
I suppose you put that on a 5 inch plug!
Since you just need an extension since the plug is the same! You bought a worthless tool! Just hope the OP doesn't buy one! When a standard 5/8 plug socket is needed.
Showing off your cluelessness again! Telling the OP to get a 5 or 6 inch plug socket? Lets see the 6 inch You must use that on your Corvette. He was asking for tips not information using the wrong tools!
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Higgs..
I can swap plugs in a C7 in 30 minutes or less, literally just finished a set ten minutes ago.
I use a curved Snap On plug ratchet, 1" extension and a standard plug socket. Not to sound like a Snap on commercial, but the right tool makes all the difference.
MSD products for late model GM's are far from a "good" product IMO, when a car comes in here with them for a build it's the first thing removed from the car. Waaay too many problems with them failing very quickly, the boots turn soft and mushy very quickly.
Do some search on OEM wires and plugs in the C6 and C5 sections. You may be surprised to learn they are both excellent ignition parts. No need to swap out unless you add a power adder (supercharger or turbocharger) then NGK copper plugs but stay with OEM wires.
Agreed completely, my 8 second car runs on stock wires just fine and they hold up very well compared to most aftermarket wires I have used.
(continuing to give great advice Rock'n)
Used them several times. There better than the stock wire. Stock wire is only 7mm. The MSD's are 8.5mm with stainless ends that actually snap on with a clic both on the plug and coil! Plus it will carry more current at less resistance than the stock wire. That's a good laugh Doug!
You should reuse the GM boot cover over the MSD boot at least on the C6 to protect the plug boots. Some people may have left those off and your seeing heat damaged boots! Yet to change a C7 plug!
Thanks for the tip, I ordered a curved ratchet with swivel head off of Amazon dirt cheap.
Send pics of the tools needed,i need some in my garage please
