Which power adder should I get?
I am seriously looking for a power adder but really confused as what to get between Edelbrock, A&A, ECS, & Procharger?
My criterias:
Target around 550-600 rwhp
Long lasting reliable kit that can go over 36000 miles
The least expensive to mantain.
Idle and drive like stock unless pushed.
The easiest to get it back to stock.
Any recommendation,
Thank you.
My criterias:
Any recommendation,
Thank you.
Joe@cordesperformanceracing.com
480-359-5914
Www.cordesperformanceracing.com
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
The A&A includes the Innovation's West Balancer that the new pulley integal to the unit.
Smoother Supercharging! NO COMPARISON here.
The bracket is not even the same.
New DESIGN has stiffer forged pieces
COST more to make and is MUCH stronger and should be lighter as well.
Less mass! Bolts on with only 4 bolts!
Almost a uni bracket with the blower. No comparison here either!
Then the intercooler design hands down A&A! Look close here!
Keeps the air flow
the right way. The air pressure (cooling air) comes it the front and out.
Not affecting the factory cooling. Where some try to block it!
A&A wins here too!
The ABS contraversy. A&A made there own little factory type aluminum brackett
that relocates it over slighlty. Comes in the kit!
Lot of serious R&D in Andy's A&A kit! I rate him second to none on making blower kits!
My order of the centri kit's? A&A, then ECS, Procharger
They are very equal they do a have a little difference as Paxton or Vortech may offer a different model. But some are the same just called a diiferent name. 6 one way or a half dozen the other on the blower heads.
