Meth location
Old Aug 3, 2014 | 12:10 PM
2014stingrayjoe's Avatar
2014stingrayjoe
Default Meth location
Can anyone tell me where exactly you are mounting the alkyl pump for the meth kit. Thanks joe
Old Aug 3, 2014 | 03:15 PM
spaceaholic's Avatar
spaceaholic
Also interested..have the same kit at the installer for this week. Assumed it would need to be close to the tank...additionally similar questions reguarding placement of electronics...
Old Aug 3, 2014 | 07:20 PM
00hotvette's Avatar
00hotvette
Mine is being installed tomorrow. I will get back.
Old Aug 3, 2014 | 07:50 PM
spaceaholic
Pictures during the install showing placement of each major component would be very welcome as well as any lessons learned .
Best -
Scott
Old Aug 3, 2014 | 09:22 PM
Motohead279's Avatar
Motohead279
Most shops are installing it behind the back of the drivers side front wheel well. The wheel well does need to be removed. I might have a pic or two from when mine was installed.
Old Aug 3, 2014 | 11:06 PM
Elite '14's Avatar
Elite '14
I believe mine was shipped out on friday so any info would help me too. If I get it before I see anything here, I will post some pics and perhaps a time lapse vid or something.
Old Aug 4, 2014 | 04:15 AM
wv8090's Avatar
wv8090
I'm using my windshield washer tank and the pump is mounted behind the bumper inside the fender, cant see a thing.
Old Aug 4, 2014 | 08:09 AM
spaceaholic
Any associated electronics inside the cockpit - if so where did you place those as well as the indicator LED's?
Old Aug 4, 2014 | 09:27 AM
wv8090's Avatar
wv8090
There is a small green LED on the pillar that lights up when the pump is energized that's it. Honestly though when I'm in the 10-12lb boost range and it kicks on I have tunnel vision and can't even see it.
I do plan on running a flow monitor gauge but I am still waiting on a decent aftermarket gauge pod...
To Meth location
