Road coarse tire pressure ?
Old Aug 13, 2014 | 12:22 AM
hankman's Avatar
hankman
Default Road coarse tire pressure ?
Going to willow springs, what should the tire pressure be ? thanks
Old Aug 13, 2014 | 02:34 AM
Seapar's Avatar
Seapar
Start 26 cold. Adjust for 32 hot , see how it feels.
Old Aug 13, 2014 | 01:53 PM
LA STIG's Avatar
LA STIG
If you are going to Big Willow I REALLY recommend getting an alignment with as much negative camber as possible, certainly -1.5 or more. Otherwise your left front could take a beating no matter the pressure.
Old Sep 3, 2014 | 03:35 PM
Tom Hewitt's Avatar
Tom Hewitt
Michelin's chief engineer told me (in person) 24psi cold
Old Sep 3, 2014 | 08:21 PM
Greg00Coupe's Avatar
Greg00Coupe
You will get lot of opinions......is one better then the other? Use what the general tells you in the manual.
A single number is not the answer, but the manual is a good starting point. You need to figure in sunny or cloudy, temperature, humidity, run time and break time.
You could run for an hour in 50 degree weather and have sever wear.......... or 15 minutes on a hot track with a 40 minute break period.......big difference.
Before I got my C7 to the track...waiting out winter..... I was reading posts about sever brake and tire wear. Folks claiming chewing up tires and brakes in one weekend!!! $$$$sss
Then talking to the guys at spring mountain and utilizing their braking techniques and taking care of the car........ I am pleased with how stock parts have held up.
I run with a group that has 3 classes of drivers for 20 minute sessions. Run about 10 laps in a 20 minute session. Lap 1 and 10 are warm up and cool down. Every other session I slow down on laps 5 or 6 if it is a hot track. Hammer it for laps 2,3,4,7,8,9 and rest the car in the middle. Between sessions I have a 40 minute break which is great to cool things down.
I see others hammering their brakes in the corners. Ron Fellows teaches to hit the brakes before you get into the corners. Funny when I smell burning brakes on the course or in the pits its always the dudes who run flat out and ride the brakes thru the corners!!!!
Sorry for the long answer........but IMHO there is not one right answer on what the pressure should be. It's your style and goals and skills too.
To Road coarse tire pressure ?
