Post your dyno graph here.
Old Aug 25, 2014 | 09:15 PM
Mariano's Avatar
Mariano
Default Post your dyno graph here.
I would be interesting to see dyno graphs comparing the low end torque of centrifugal vs twin screws (roots) S/Cs on the LT1. This would be useful for someone like me who's in the market for a forced induction system.
As we all know, the twin screws will produce superior low end torque numbers over the centris. I want to see what those differences are, and at what rpm. So far I have only seen one LT1 dyno graph for a centrifugal S/C. I compared it to my Magnacharged Camaro and difference in bottom end torque was significant (80 ft lbs @ 3500 rpm), but comparing a LS3 to a LT1 is not apples to apples.
I'm guessing I'll see very few (if any) twin screw graphs posted, because the only one available at this time is the recently introduced E-Force. Nevertheless, seeing several centrifugal dyno graphs would still be helpful and informative.
If you have a dyno graph chart of your supercharged C7, please post it here. Thanks.
Mariano (Alfie)
Old Aug 27, 2014 | 11:30 PM
Mariano's Avatar
Mariano
I can't believe nobody has tuned their S/C install on a dyno ???
Old Aug 28, 2014 | 09:25 AM
Daniel@Vengeance's Avatar
0Daniel@Vengeance
Former Vendor
You can see most of our supercharged C7's graphs in their individual threads in this link: https://www.corvetteforum.com/forums...solidated.html
Unfortunately there hasn't been a true "roots" style supercharger on the market for the C7 until Edelbrock's recent release of the E-Force systems. We will be adding these to our inventory very soon, and hope to install our first unit in the near future.
Old Aug 28, 2014 | 04:21 PM
Mariano's Avatar
Mariano
I understand the Magnacharger for the LT1 might be available in the near future. Will you be adding those to your inventory as well? Thanks.
Mariano (Alfie)
Old Aug 29, 2014 | 10:17 AM
0Daniel@Vengeance
Former Vendor
Mariano (Alfie)
Yes sir, we are a full Magnuson dealer so we will be adding that system as well once it is released.
Old Aug 31, 2014 | 11:48 PM
3 Z06ZR1's Avatar
3 Z06ZR1
Mariano (Alfie)
Your low end numbers end in a split second. Then once you hit 6500
in first gear then hitting each shift. You are always above the "low tq numbers" your talking about.
Rather more important is the pulling power in the upper RPM's much like a cam install. High Tq cams in the low RPM's are slower.
Than the cams that makes better high RPM number Ie Horsepower.
Old Sep 1, 2014 | 10:42 AM
Mariano's Avatar
Mariano
Yes, that is correct, but that applies to someone who is racing. I once raced (drag) an 8000 rpm small block with 5:86 final gear; I understand the use of top end power in high rpm racing applications.
What I failed to mention in my OP is: I will not race this C7. Therefore, I want tons of low rpm torque. Bottom end "seat-of-your-pants" torque is fun and preferred on the street.
My brother's Whipple GT 500 makes 700 HP, and would beat my my 650 HP 2010 Magnacharged Camaro in a 1/4 mile, but even he would admit, my Camaro was much more fun to drive on the street. The difference? At 3000 rpm, my Camaro pulled over 100 ft lbs more torque that his Mustang. Torque baby! Much more enjoyable on the a** dyno.
Thanks for your input.
Mariano (Alfie)
Old Sep 1, 2014 | 08:35 PM
3 Z06ZR1's Avatar
3 Z06ZR1
Mariano (Alfie)
To each his own! But
I like the face distorting pull of the upper range pulling power
that a centri provides.
Old Sep 1, 2014 | 09:03 PM
Mariano's Avatar
Mariano
OK. You like your face distorted at 5000-6000 rpm, but I like my face distorted from 2500-6000 rpm.
More to the point. You are in Oregon and I'm in Michigan. That makes Nebraska about the mid-point, right? There are a lot of long straight roads in the corn fields of Nebraska. I'll meet you there and we'll have a "twin screw vs centrifugal drag show down".
It's on! Best two out of three.
Mariano (Alfie)
Old Sep 1, 2014 | 10:30 PM
"BoneStock"'s Avatar
"BoneStock"
I have a ecs kit on my c7 and had a 03 cobra with a whipple on e85. The cobra felt much faster even tho they are probably close to the same. I live the sound of the novi 1500 and it pulls really hard in the upper rpms. All personal preference but the termi felt faster.
Old Sep 1, 2014 | 11:57 PM
Mariano's Avatar
Mariano
When you talk about the sound that you love, are you talking about the sound at wide open throttle, or are you referring to the blow off valve sound at low throttle high vacuum? Is the BOV loud at idle...at cruise?
Mariano
Old Sep 2, 2014 | 10:05 AM
"BoneStock"
Mariano
Im referring to the bov. I got the louder one and it sounds like a jet cruising around at 2-3k rpms and when you let off. Doing a burnout it just sounds nasty.
To Post your dyno graph here.
