Bearings in the engine
Old Oct 2, 2014 | 08:46 PM
charliecleanup's Avatar
charliecleanup
Navigator
Default Bearings in the engine
Hi anyone know if the bearings are still metal or if they are now plastic?
thanks
Old Oct 2, 2014 | 09:19 PM
RicK T's Avatar
RicK T
Polymer coated:
https://www.corvetteforum.com/forums...-bearings.html
Old Oct 4, 2014 | 11:59 PM
JeffInDFW's Avatar
JeffInDFW
That is bad news. They switched to that in 2012, and members of this forum have seen a jump in main bearing failures in 2012 and 2013 cars. The C6 Z06 sub forum has many threads on the subject.
"Until the 2012 model year, bearings of traditional, "tri-metal" (steel backing, bronze second layer and a top layer of lead) construction were used in the LS7's #1, 2, 4 and 5 main bearing positions and in the connecting rods. European Union legislation enacted in 2011 prohibits the import of products containing lead, so the main and con rod bearing designs were changed. Lead was replaced with a synthetic polymer making a "bi-metal-with-polymer" design. The center (#3) main bearing remains aluminum on a steel backing. According to Mark Damico, because of the firing order used on all Gen 3, 4 and 5 V8s, the second and fourth main bearings are subjected to the highest loads. After a long period in service, if an LS7's bearings are going to wear, it'll be the #2 and #4 mains which show it, first. The two end bearings may see a lesser level of wear due to (#1) the accessory drive or (#5) the flywheel. The center main experiences the least vertical load and while it is an increased-eccentricity design, it's never required a lead overlay nor polymer coating."
To Bearings in the engine
