NPP exhaust actuators
Old Nov 1, 2014 | 11:25 AM
fredmills's Avatar
fredmills
Default NPP exhaust actuators
Looking to install NPP exhaust (hopefully used). Will leave them open and not try to connect electronics. Do I need the actuators (unwired) to seal off the exhaust or is the damper rod (?) self sealing?
Old Nov 1, 2014 | 01:08 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
This is a good question. I swapped mine and got lucky that the valve actuators came with the NPP I bought but based on what I remember seeing with the actuators removed, it would be a good idea to cover the hole with something. If not I could see the mechanics of the valve possibly get rusted out over time. My .02..
Old Nov 2, 2014 | 09:53 AM
fredmills's Avatar
fredmills
Thanks. Assume you are running wide open all the time. Any thoughts or problems.
Old Nov 2, 2014 | 04:02 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Yes running open all the time. No problems whatsoever. Car still gets quiet when the AFM valves open and close but I typically drive in Sport mode so its usually always loud.
Old Nov 3, 2014 | 09:24 AM
fredmills's Avatar
fredmills
Thanks for info. Very helpful. I think I can proceed knowing what to expect.
WTB. Any one have NPP exhaust for sale. Several thousand miles - ok.
Old Nov 6, 2014 | 11:46 AM
06MonteSS's Avatar
06MonteSS
Supporting Vendor
I have the NPP exhaust on my 2014 Camaro SS..
one of the first things I did was to pull out the fuse for it, so the baffles just stay open all the time
No issues/problems at all.. and sounds great...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS LS3, short-throw shifter, NPP perf. exhaust, BMR strut-tower brace, Cold Air Inductions cold air intake, catch-can, ported/polished TB, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Nov 6, 2014 | 12:37 PM
vettekat2007's Avatar
vettekat2007
Does anyone know if there is a fuse that can be pulled on the C7 and if so where is it? Has anyone done this and did you experience any problems or error messages? Thanks.
Old Nov 6, 2014 | 02:09 PM
06MonteSS's Avatar
06MonteSS
Supporting Vendor
on my camaro, it was in the fuse box in the trunk, behind the trunk liner.. a 10 amp blue fuse.. labeled EXHST FLAP I believe...
so check your fuse boxes in the car and look for that... should show you the fuses in your owners manual too so you can find it in there first...
Old Nov 6, 2014 | 02:15 PM
shreded1's Avatar
shreded1
I believe it's fuses 41 and 32. If you do a search there are many threads on this.
Old Nov 6, 2014 | 02:18 PM
06MonteSS's Avatar
06MonteSS
Supporting Vendor
there was only 1 fuse to pull for it on my car..
there is also a relay for it.. but you do not want to pull out the relay.. all you need to do is remove the fuse...
Old Nov 6, 2014 | 02:37 PM
Theta's Avatar
Theta
St. Jude Donor '14-'15
Fuse 41 only for 2014 NPP (changed on 2015). 32 was for AFM.
Old Nov 6, 2014 | 11:30 PM
owc6's Avatar
owc6
Why yes I do. I've got one. I've got all the original exhausts for '05, '09 Z06, and for my "14 Z51. Big basements make for lazy resale. Make it worth my while.
To NPP exhaust actuators
