A6 downshift issue.
Old Nov 1, 2014 | 06:39 PM
Skialta's Avatar
Skialta
St. Jude Donor '14-'15
Default A6 downshift issue.
2014 vert, A6. In , and only when I'm in Sport mode. When it's "punched" and the tranny drops to second gear the tranny stays in second. Let off the gas, it stays in second. If I change to Touring mode it gets her back to normal, or use the paddle shifer. I checked the last time this happened and the tranny temp was at 175 at the time. I called the dealer they gave this info to the Corvette guy, I'm awaiting his call back.
She runs as expected in all other modes and conditions.
Anyone else seen this in the A6 ?
Old Nov 1, 2014 | 06:53 PM
robertf97's Avatar
robertf97
Yes, I thought it was an intentional rev matching type feature but I could be wrong. It has happened to me in track or sport mode.
Check out this article:
"That's where the Drive Mode Selector comes in. In the standard Touring setting, the automatic provides quick, efficient shifts. But turn the dial to Sport, and it'll hold longer in the lower gears. This software setting is identified by the acronym PAL (Performance Algorithm Lifting), for the "lift foot" style of shifting.
Read more: http://www.superchevy.com/how-to/131...#ixzz3HrQNJPIS
Old Nov 1, 2014 | 07:19 PM
WKMCD's Avatar
WKMCD
I believe it's just going into the Performance Shifting Mode. It return to normal eventually.
Old Nov 1, 2014 | 07:35 PM
NSC5's Avatar
NSC5
Staying in a lower gear is normal once more aggressive driving occurs, GM refers to this as "PAL" for Performance Algorithm Liftfoot" and it has been used for a number of years in various automatic equipped GM vehicles. The first time I experienced it was in my 2008 Cadillac CTS when shortly after it was fully broken in I accelerated hard to merge onto an interstate after the car ahead of me decided to slow and pull to the shoulder in mid-merge. It was startling when it happened but it shifted up normally after a short time at sustained cruising speed.
Old Nov 1, 2014 | 09:55 PM
Snorman's Avatar
Snorman
Scraping the splitter.
St. Jude Donor '13-'14-'15
As already stated, it sounds like it's going into Performance Shift Mode, which occurs with even a brief WOT stab. You should see a message on the DIC stating "Performance Shift Mode Active". It will stay in the current gear, I believe, until redline before shifting. This is similar to "Sport Plus" mode on the Porsche PDK.
S.
Old Nov 2, 2014 | 08:55 AM
yell03's Avatar
yell03
It is supposed to do that, the car thinks you want to play so it gets in to a Performance Driving Mode.
I have a 2014 C7 Vert A6 also and it does it all the time.
You will also notice it even more pronounced in track mode.
After you do this watch as you slow down for a light or a turn the car will rev match downshift, pretty cool.
It does get a little annoying when passing on the highway and waiting a bit for the revs to come back down, but the automatic tranny is worth it to me.
Old Nov 2, 2014 | 09:36 AM
cobra502's Avatar
cobra502
Default A6 doen shift
I have found that if you don't want this to happen simply make a quick shift from drive to neutral and back again to drive and it will stop rev matching.
Old Nov 3, 2014 | 02:51 PM
hankman's Avatar
hankman
This is correct.
Old Nov 3, 2014 | 05:15 PM
ProChargerTech's Avatar
0ProChargerTech
Former Vendor
I always thought it was a really cool feature once you get used to it, and know its there.
Old Nov 3, 2014 | 07:15 PM
WKMCD's Avatar
WKMCD
Old Nov 3, 2014 | 09:01 PM
dbdave's Avatar
dbdave
Better yet, tap the upshift paddle and it will upshift to the next higher gear and return to normal.
Old Nov 4, 2014 | 06:59 AM
yell03's Avatar
yell03
Never thought of that, great solution
To A6 downshift issue.
