Magnetic Select Ride Control
If you have the extra dough and can find one like you want that has MRC, I would defeintely go for it. But, unless you are . . . how shall I say this . . . "delicate", you won't mind the standard z51 ride at all. I'm 40 years old FWIW and my wife drives the car as well - no complaints from either one of us - we absolutely love the car and I don't even think about MRC when I drive it.
It's pretty cool, really softens up the ride over those rough nasty roads when you go from track or sport down to tour. BIG difference, lot bigger then I expected.
If you can spring the $$$, do it.
Z51 is great no extra weight. Just perfect ride!I don't seem to miss it! Likely the best shock GM EVER put on a Car
let alone the Corvette!
MRSC is one of the reasons I bought the car.
The next easiest way is to look for the FE4 code on the build code label under the trunk carpet.
GM has to pump the koolaid to the prospective buyer to make the sale.
Then once you have bought several Corvette's you decide what you as
a buyer want. All buyers are different.
I have it on the ZR1 and find it not needed. I leave it in sport.
Just like heated seats and the hud. Many like that and other not needed options.
Come to a curve in the road and the touring setting is a compromise
in handling. I would rather have the same sports car feel all the time.
No dreaming of or wanting a Cadillac ride here. In my Corvette's.
Best feature of the 1lt is the lighter weight of the missing options
NOT used.
Add the weight and lose the sports car!
Look at a lot cars too much weight added.
Just like all the other options you add to the car add weight.
You want add the weight of the options (extra weight)
then mention performance in the same breath? Not much sense.
The Standard Z51 comes with the best shock GM has ever used by a long way. If you drive one you'll see the shock is perfect match for the
spring and is one excellent ride 100 percent of the time.
Mag ride is far from needed the standard Z51 is great.
I had MRC on my Audi TTRS and it is AMAZING!!! I could take on-ramp sweepers with less than perfect pavement at over 110 MPH with no drama whatsoever and that was with RE-11 tires that could load up the suspension at higher speeds than the stock tires. I can say my Audi TTRS handled way better than my M3 did (which is supposed to be a superstar in the handling department)
You get the body control/stability of a coil-over without having to actually buy a coil-over system. Also unlike most coil-over packages its great to be able to change the comfort level on the fly in the car rather then having to change dials on all 4 corners.
