Maximum torque for C7 Z51 drive train
Here is a different but similar question to the engineers. What torque level do you think the C7 Z51 standard stick drive train is capable of reliably handling (assuming stock tires). And why do you think this?
I know Hennessy and Lingenfelter say it can hold a lot more than what the stock or Z51 engine set-up can deliver, but what do the engineers think it can reliably handle? I see all kinds of 550, 600, 625, 650, 675, 700 and up-grade packages via Lingenfelter and Hennessy, and others, but what do the engineers say that it can handle reliably for, oh, say 100,000 miles of semi-rigorous driving?
Any engineering based advice?
Nick
Nick
However I have seen two posters on here with broken differentials that had put on stickier tires and dumped the clutch at elevated RPM. They had superchargers and were probably running ~600 ft-lbs. That's an instantaneous shock load.
That makes sense as engineers usually spec things at least 20% stronger than the load they will see (1.2 safety factor) for long term durability, which would be 460*1.2= 552 ft=lbs. 600 would be a 1.3 safety factor. I used 1.25 frequently when I designed automotive components. So I would split the difference and say 575 ft-lbs.
Good luck.
... engineers usually spec things at least 20% stronger than the load they will see (1.2 safety factor) for long term durability, which would be 460*1.2= 552 ft=lbs. 600 would be a 1.3 safety factor. I used 1.25 frequently when I designed automotive components. So I would split the difference and say 575 ft-lbs. Good luck.
So... In your example you used engine specs. I now have 550 ft-lbs to the rear wheels on a Z51. But a couple of things may work in my favor:
A. I never dump a cluch under any rev conditions.
B. I do have stock tires for the Z51 package.
C. I would floor it only after engaged in a gear and only after moving forward absorbing some torque that could go to breakage.
So from where I sit. I think I am fine on the broken part front as long as I a careful.
Do you agree? Or. Hmmmm, does the 2015 Z06 have a different transmission, rear trans-axle, long and shot shafts, or are these the same as the 2014 Z51. That is; they did what Volkswagen did in the early days, i.e. built a diesel block and use it for gas as well making it great for turbo charging gas as well?
I do not know, but it is fun to think about.
Nick
Nick
Z06---650 lb-ft of torque x 2.29 = 1489 lb-ft to the differential.
Z51 with 501 lb-ft(engine modified) of engine torque X 2.97 = 1489 lb-ft to the differential. Stock Z51 delivers 1381 lb-ft to the differential.
As you can see, if the Z51 was modified to 650 lb-ft, it would have 1931 lb-ft of torque delivered to the differential. Much more than the Z06 delivers to the differential.
Those numbers are calculated on torque at the flywheel, not torque calculated based on the results shown on a chassis dyno.
The most power I have made in my supercharged applicaion was 610whp, and 570-580 ft lbs of torque.
All I can tell you, based on REAL experience is be careful with these cars. There are limited options out there aftermarket, and it is verrrrrry frustrating.
Good Luck!
Good Luck!
Good Luck!
Nick
