Took us about 1hr to remove the front bumper and reinstall. When you first get the grill it looks like it won't fit. I highly recommend removing the bumper as the clips that hold the grill could be difficult to clip of. But it could b done with out removing.
Did you have any difficulty with the "clips" around the headlights. I keep reading about that but I can't picture it nor are there any good pics of the offending clips.
Btw is this the grill without the additional brake cooling ducts?
You can't really see the clips next to the headlights. I knew I had to pull straight up to get it off though. After my install, I read that if you tip the nose up and get under you can try to access the tabs that are holding it in place to get an easier release.
We did not have any problems removing the front clips around the head lamps. We use a swivel to remove the bolts. U will need to push up on the bumper in oder to get to them.
I couldn't agree more that the "retainer" ring looks like someone wearing a retainer. Maybe GM will do away with it in 2016 or make the Z06 grille an option when ordering a 2016.
