LT1 vs LT4
Old Dec 22, 2014 | 11:36 PM
0v3rc10ck3d's Avatar
0v3rc10ck3d
Default LT1 vs LT4
Does the LT4 have the same 6.2L motor as the LT1 with the addition of a blower? If so did they upgrade any internals?
Old Dec 23, 2014 | 03:11 AM
0v3rc10ck3d
Are the LT1 and LT4 parts interchangeable? Could you built an LT4 by simply swapping parts onto an LT1?
Old Dec 23, 2014 | 12:20 PM
C7&7's Avatar
C7&7
Yup they're interchangeable, it wouldn't make sense to go through all that work when you could build something better but...
Both 6.2 liter engines. The lt4 just has some tweaks to be blower friendly. Similar to the LS3 and the LS9 that was in the C6-ZR1.
Old Dec 26, 2014 | 05:35 PM
Shaka's Avatar
Shaka
General Motors’ powertrain engineers adapted the naturally aspirated LT1 foundation to generate some 40 percent greater output using forced induction. An all-new, ultra-efficient version of the Eaton twin-vortices supercharger design (see sidebar) delivers the air, but supporting the boosted airflow and the crankcase pressures it generates required a comprehensive makeover inside the cylinder walls—not only to help produce the power, but also to ensure that it is delivered with the civility and durability this daily-drivable supercar requires.
Cylinder block and rotating assembly
The LT1 and LT4 share the same 319 cast-aluminum cylinder block with 4.06-inch bores, as well as the small-block family’s signature 4.40-inch bore centers. Additionally, piston oil squirters are employed in both applications. The two engines also use a tough, 1538MV forged-steel crankshaft with induction-hardened journals and intermediate pin drills, but the LT4 features ground pin collars and heavy-metal (tungsten) balancing material.
Components differ among the parts attached to the crankshaft as well. Like the LT1, the LT4 uses 6.125-inch-long forged, powdered-metal connecting rods, but they’re highly machined for greater strength and reduced reciprocating mass. They have the same balance mass as the LT1 rod but a higher load capability, with exclusive features including machined lightening slots and a “stepped” pin end with a premium bushing.
The LT4 also uses unique forged-aluminum pistons with a structure designed to cope with the more intense cylinder pressures that come with forced induction, including strength-enhancing internal ribs similar to those used on the LS9 pistons. A flat crown, or head, helps reduce compression from the LT1’s 11.5:1 ratio to a more boost-friendly 10:1.
Other LT4-piston exclusives include a unique ring pack designed for greater wear resistance and durability under extreme conditions. It comprises a PVD-coated top ring, a chrome-coated second compression ring and a nitrided oil-control ring. The bottom ring land also features eight oil drains. Friction-reducing skirt coatings are used on both the LT1 and LT4 pistons.
Finally, the LT4 features a floating piston wrist-pin design, as on the LT1, but with a unique, diamond-like coating for added durability and lower friction.
Oiling system
The LT4 features a standard dry-sump system with a 10.5-quart capacity—the same setup that’s included on LT1 cars equipped with the Z51 package. (The LT4 does get a higher-capacity oil cooler.) Otherwise, the basic oiling configurations of the two engines are similar, which means they use a dual-pressure-control, variable-displacement vane pump driven by the crankshaft. This unconventional design ensures that the engine always receives a sufficient supply of oil, regardless of rpm.
GM recommends its Dexos semi-synthetic motor oil for use in all Gen V small-block engines; 5W30 is the recommended weight for the LT1 and LT4.
Camshaft
The LT1 and LT4 differ more dramatically in the valve-actuation attributes of their respective hydraulic roller camshafts. The naturally aspirated LT1 cam specs include 0.551/0.524-inch intake/exhaust lift, 200/207 degrees duration at 0.050-inch lift and a 116.5-degree lobe-separation angle (LSA).
The LT4’s camshaft, on the other hand, is designed to help process a much greater amount of airflow under boost, with a wider, 120-degree LSA that reduces overlap and opens the exhaust valves just a little earlier. It holds it them open longer, too—for 223 degrees of crankshaft rotation—and delivers a lift rating of 0.551-inch. The intake specs are actually reduced somewhat from the LT1: 189 degrees of duration and 0.492-inch lift.
Overall, the LT4’s camshaft is relatively mild, thanks to the torque-enhancing benefits of the supercharger. The result is smooth operation at low engine speeds, particularly at idle. The wider LSAcontributes to that smoothness, while also helping to flatten the torque curve and hold power higher in the rpm band.
Both the LT1 and LT4 feature dual-equal camshaft phasing (variable valve timing), which works with Active Fuel Management to enhance fuel economy and maximize engine performance for given demands and conditions. A vane-type phaser is installed on the front of the camshaft to change its angular orientation relative to the sprocket, thereby adjusting the timing of valve operation on the fly. “Dual equal” denotes that the system adjusts both intake and exhaust valves at the same rate.
The different cam specs mean different timing and rates of phasing between the engines, but the mechanics of the system are shared.
Cylinder head and valvetrain
The LT4 features the same combustion-system design as the LT1, to support the direct fuel injection, but it uses stronger, more heat-resistant Rotocast A356-T6 aluminum cylinder heads in place of the LT1’s conventional 319-T7 cast-aluminum units. The Rotocast manufacturing process involves rotating the mold during casting to eliminate porosity and ensure a denser, more accurate component.
Given the LT4’s pressurized induction, special attention was paid to sealing its heads. Upgrades here include thick, seven-layer stainless steel head gaskets—similar to those used on the LS9—and 12mm head bolts made of hardened stainless steel.
To help reduce compression and better process the supercharger’s massive intake charge, the LT4 features 65.47cc combustion chambers, as opposed to the LT1’s 59.02cc chambers. The LT4’s 10:1 compression ratio is nevertheless high for a forced-induction engine, but the greater combustion control of the direct injection system helps prevent detonation.
In both engines the valves are held at 12.5 degrees (intake) and 12 degrees (exhaust), and splayed 2.61 degrees (intake) and 2.38 degrees (exhaust); this configuration reduces shrouding to enhance airflow. The LT4 uses lightweight, 2.13-inch, solid-titanium intake valves, which feature exceptional heat resistance and superior high-rpm strength as compared with the LT1’s identically sized hollow units. The 1.59-inch, sodium-filled exhaust valves are the same for both applications.
Valvetrain components for both engines include high-rpm, beehive-type valve springs; 1.8-ratio roller-pivot rocker arms; and large, 8.7mm (outside diameter) pushrods.
Fuel system
The LT4’s direct injection system is similar to the LT1’s, but it features a new, higher-pressure engine-driven pump capable of delivering fuel at an astounding 2,900 psi. The LT1 pump is capable of “only” 2,175 psi. The LT4 also features a unique, higher-capacity fuel-rail assembly designed to accommodate the supercharger manifold. It’s fitted with injectors rated at 1.5 liters per minute, while the LT1 uses 1.2-lpm squirters.
GM’s Active Fuel Management cylinder-deactivation system carries over to the LT4. It’s capable of temporarily deactivating four of the engine’s cylinders at light loads to reduce fuel consumption. The transition between four- and eight-cylinder power takes less than 20 milliseconds and is virtually imperceptible.
Additional differences
Besides the supercharger and its complementary accessory-drive system, the LT4 also uses stainless-steel exhaust manifolds in place of the LT1’s conventional iron ones. Equipped with smooth flow passages and equal-length runner geometry, their flow performance is comparable to that of the high-flow manifolds used on the LS7 and LS9 engines.
Finally, a lightweight aluminum balancer stands in for the LT1’s cast-iron unit.
Old Dec 26, 2014 | 08:19 PM
0v3rc10ck3d
Wow. Thanks! Just what I wanted to know. Haha
Old Jan 4, 2015 | 12:52 PM
agbullet's Avatar
agbullet
Wow, that is an AWESOME write up! Do you know if its possible to upgrade the LT1 to the LT4 fuel system? injectors, rails & pump?
Old Jan 4, 2015 | 01:49 PM
jimman's Avatar
jimman
Better, really
Old Jan 4, 2015 | 11:28 PM
C7&7's Avatar
C7&7
Originally Posted by jimman
Better, really
Yea...really...
Why tear into a motor to replace heads or a cam and swap a lt1 part for a lt4 part when there are way better aftermarket options that would make better power.
Thats what's meant.
Old Jan 4, 2015 | 11:45 PM
jimman's Avatar
jimman
Yea...really...
Thats what's meant.
There's more to it than power..
Old Jan 5, 2015 | 09:37 AM
C7&7's Avatar
C7&7
Oh?
So we're going to replace LT1 parts with LT4 parts for what? Looks? Not sure where you're going with this.
I understand someone wanting to use genuine GM parts from a LT4 motor, but my point was if you're going to go through all that effort, time, and money why not put something in it that will perform better. The warranty is out the window in either situation.
Old Jan 5, 2015 | 09:52 AM
W88fixer's Avatar
W88fixer
Not at all confident that the aftermarket process is going to give you a better product, more HP if you want that but HP plus durability??? Next to impossible for the aftermarket to invest the computer design time that GM has in this engine. Don
Old Jan 5, 2015 | 10:07 AM
jimman's Avatar
jimman
Thanks for making my point.
40 years, 10 Corvettes, 1.75million miles and the ONLY thing that ever broke was aftermarket garbage designed to correct the ill's of GM, right.
Old Jan 5, 2015 | 11:01 AM
Higgs Boson's Avatar
Higgs Boson
Oh ok, so based on that logic, 650 HP is the most a supercharged V8 can make without breaking. Good to know.
Old Jan 5, 2015 | 02:04 PM
leadville1's Avatar
leadville1
I think GM would sell more Z06's if they built an actual race motor for this car, not unlike what BMW does with M engines. Adding a roots blower to a track car isn't really how I would go about building a track dedicated machine.
If they took the LT1 and made it a stroker or higher reving motor I think that would be much more desirable. If your going to have a built motor from the factory, it would have been better for it to be built for it's purpose.
Motor Trend did 4 laps at Road Atlanta and had to bring the car in because it already had high oil temps. The Z06 makes no sense to me as a track car, unless your definition of a track is 4 laps. The LT4 may be a good FI motor but it isn't a race motor.
To LT1 vs LT4
