Question about camming a 2015
Old Dec 28, 2014 | 11:26 AM
artz66's Avatar
artz66
Veteran: National Guard
Default Question about camming a 2015
Ok I have my order in for a 2015 z51 with a m7. I had a great engine build on my 2012 camaro SS m6 that I sold a few months later. I'm wanting to copy the build as close to possible when the time comes to crack into the motor. The Camaro was built with a supercharger in mind and this time I'll probably add the supercharger and meth first.
The camaros build was as follows
Jannety Race Engineering Rough Idle blower cam, Brian Tooly Racing push rods, Precision Racing Components 6.75 springs, comp cam trunion upgrade halltech CAI, K&N filter, Manley H/V oil pump, Kooks 1 7/8 headers w/o cats, ported TB.
The reason I'm wanting to copy it is because everything worked perfectly. It made good power and was very street able. Had a great lope to it but not drastic and the exhaust sound through the factory npp was outstanding.
So with that being said. What all is needed to properly do a cam in a 2015. I've searched and can't find much information on the subject.
Old Dec 28, 2014 | 12:03 PM
robertf97's Avatar
robertf97
The most important things are 1) to get a larger fuel pump lobe if you expect to make over 600whp 2) you will need to delete AFM and use ls7 lifters for the cam to be big enough to be effective 3) If you go too big on the cam, the VVT wont retard the cam properly at high rpm. Good luck.
Old Dec 28, 2014 | 12:27 PM
jim2092's Avatar
jim2092
Veteran: Marine Corps
St. Jude Donor '08
Check with forum sponsors LMR in Houston and Vengeance. They have done a lot of work and R and D on C7 cams.
Old Dec 28, 2014 | 01:10 PM
artz66's Avatar
artz66
I've looked around at vengeance site and love what they do. However there cam kit is 9k with headers and an air intake. Maybe that's the price for needing the afm vvt done but I hade 5600.00 in my camaro and that's installed by cbi street cars and tuned by dsx tuning. Look them up. They are top notch guys in saint Louis area.
Oh well it's a learning experience and you gotta pay to play the hp game.
Old Dec 28, 2014 | 03:14 PM
ZO6ME's Avatar
ZO6ME
Get with Chad he knows what's needed. That's what sucks with these cars. Cam swaps are a lot more on these motors. Texas Speed heads cam is showing good results.
Old Dec 28, 2014 | 03:16 PM
Bucknut2006's Avatar
Bucknut2006
Heads are going to carry a premium since they are specific to the LT1 w/DI and AFM.
Old Dec 29, 2014 | 10:18 AM
"BoneStock"'s Avatar
"BoneStock"
He said he is doing meth so he doesn't need it to get over 600whp but it definitely wont hurt! Mine makes 650whp with long tubes, ecs kit, and meth.
Old Dec 29, 2014 | 10:33 AM
Jason 98 TA's Avatar
Jason 98 TA
Premium Supporting Vendor
Do not worry we have you covered on all of this! We have engine dyno tested & spec'd camshafts as well as cnc ported exchange LT1 heads for your install.
Not only that we also have the TSP long tubes for the C7 in stock! You don't have to pay $2000 for long tubes! The TSP system has the longest primaries on that market for huge torque gains & awesome power output.
Here's a dyno from one of the TSP camshafts on a LT1 engine.
Old Dec 29, 2014 | 11:51 AM
robertf97's Avatar
robertf97
This is true but I like to have the redundancy. It gets complicated if you run out of meth or the pump quits. Depends on if it is tuned to failsafe, what power level you are cutting from, if you have your IAT sensor relocated.
Old Dec 29, 2014 | 01:21 PM
artz66's Avatar
artz66
When all is said and done with my build I am hoping to be 700+ rwhp. It will be in stages though.
Old Dec 29, 2014 | 05:38 PM
Jason 98 TA
We do the cnc porting in house unlike just about every other shop on corvetteforum. As a result we are the manufacturer so the cost doesn't get marked up tons of times.
I'll double check but I think we are just over $2,000 for heads & cam with pushrods & spring kit!
Old Dec 29, 2014 | 06:28 PM
artz66's Avatar
artz66
do you guys offer custom grinds for cam. I'd like it speced to my Camaro cam. That was designed with to work well with boost.
Old Dec 30, 2014 | 11:36 AM
Jason 98 TA
Absolutely. That being said remember these engines are DI & have different specs completely. I'd really rather spec you something based off all the knowledge we gained from engine dyno development.
They are truly a different animal!
Jason
To Question about camming a 2015
