X-pipes: stock vs. Borla vs. Corsa
Old 08-23-2017, 05:54 PM
  #321
iced
iced's Avatar
So basically the borla and corsa will be louder than the unbranded pipes with resonators. You already have primary CATS, the reason why you want to remove the secondary CATS is to make the car louder and have better flow through the exhaust line.
Having resonators will make it a little bit louder than stock, but will hamper a little bit of the flow as opposed to not having a resonator (borla/corsa). Not a huge difference, but it will be there, in a Dyno anyway.
Old 08-23-2017, 07:32 PM
  #322
Silver&Blue
Silver&Blue's Avatar
Originally Posted by Kracka
No issues. The rear secondary cats are not monitored.
Where do you take your car to get inspected? I'm looking to get bola x-pipe myself. I see you live in prosper I'm in fort worth. I would drive near there to know i wouldn't have any problems with inspection.
Old 08-23-2017, 07:35 PM
  #323
Kracka
Kracka's Avatar
Received 5,716 Likes on 2,921 Posts
Just my Chevy dealership, nothing special
Old 08-23-2017, 07:48 PM
  #324
Silver&Blue
Do you get your oil changed there as well?
Old 08-23-2017, 09:36 PM
  #325
div7racer
div7racer's Avatar
Default how loud /
I installed the Manzo unit, and it is more than just a little bit louder. Actually, with the NPP closed it is just a bit louder. When they open it is A LOT louder !
Mike Campbell (08-25-2017)
Old 08-23-2017, 10:07 PM
  #326
Kracka
Kracka's Avatar
I did in the past, while still using my freebies.
Old 08-23-2017, 11:13 PM
  #327
iced
iced's Avatar
It might not be a true resonator with the Manzo then. Glad to hear it's loud! That's what Xpipes should be like!
I bought the Borla Xpipe!
Old 08-24-2017, 01:03 AM
  #328
div7racer
div7racer's Avatar
What the " replacement" for the secondary cats are on the Manzo look like are just some units that I would call an old style glasspack.
Old 08-24-2017, 05:01 AM
  #329
fatsport
Support Corvetteforum!
fatsport's Avatar
Put my Borla X-pipe on a couple weeks ago. This is what the car should sound like from the factory, absolutely rocks above 4K rpms
Old 08-24-2017, 10:13 AM
  #330
iced
iced's Avatar
I can't wait to put mine on!
Old 09-23-2017, 03:46 PM
  #331
spinkick
spinkick's Avatar
Hey thanks for the comparison and the advice on the jack points to do the work with hand tools
Old 09-23-2017, 03:50 PM
  #332
Kracka
Kracka's Avatar
You're welcome!
Old 10-22-2017, 11:06 AM
  #333
BMadden
BMadden's Avatar
Received 1,837 Likes on 660 Posts
A lot of helpful info in this thread. A refreshing change from the "mine is better than yours" that so often occurs on this forum. Think I'll be putting the Borla on my Z in the spring.
Old 10-22-2017, 11:13 AM
  #334
Kracka
Kracka's Avatar
Glad you enjoyed, thank you!
Old 10-22-2017, 01:07 PM
  #335
MerakiAutoworks
Supporting Vendor
MerakiAutoworks's Avatar
Contact us for pricing on either or!
-Josh
Old 01-19-2018, 11:30 AM
  #336
Johnp94
Johnp94's Avatar
Thanks Kraka, I did not know this is DIY.
Old 03-07-2018, 11:09 AM
  #337
B-Vette
B-Vette's Avatar
Great thread on this, thanks!
To X-pipes: stock vs. Borla vs. Corsa
Old 03-07-2018, 11:25 AM
  #338
MDPD23
MDPD23's Avatar
What is the difference between Borla X pipe 60547 and 60548?
MerakiAutoworks (03-07-2018)
Old 03-07-2018, 11:26 AM
  #339
Kracka
Kracka's Avatar
47 replaces the factory secondary cats (easy bolt-in install), 48 retains them (install requires cutting).
Old 03-07-2018, 11:29 AM
  #340
MDPD23
MDPD23's Avatar
Thanks, so the 47 do not have the cats, correct?
Quick Reply: X-pipes: stock vs. Borla vs. Corsa
