Tour cluster setting and icons
Old Jan 22, 2015 | 02:28 AM
Nobull's Avatar
Nobull
Default Tour cluster setting and icons
I have also posted this question on the general discussion forum. When I put the car into link to drive mode and call up the Tour mode and instrument cluster there is a cluster of gears icon on the right side of the screen. It seems like something is supposed to go into the space (i.e., oil pressure, oil temp, etc). Do we have the option of calling up information into this space? When I try to toggle something into this space using the DIC controls nothing happens. Any ideas out there?
Old Jan 22, 2015 | 09:03 AM
BRCC's Avatar
BRCC
Use the left arrow on the pad (page up or down) to Info or Perf and push Sel once in one of those you can page Up or Down to select the center display. As an example in Info you can select Trip A, Trip B or Instant Mileage with V4/V8 indicator.
Is this what you are asking????
Old Jan 22, 2015 | 01:17 PM
FiremanC7's Avatar
FiremanC7
Push the Left Arrow on the right steering wheel switch. Use the up or down arrow to select "PERF" and you will see information displayed in the area you are writing about. I believe you get water temp, oil temp, oil pressure and tire inflation.
BobD
To Tour cluster setting and icons
