2015 C7 brake pads
Old Feb 2, 2015 | 09:15 AM
GARYR's Avatar
GARYR
Default 2015 C7 brake pads
This may be a stupid question, are the brake pads in the Z51 package ceramic. I have one coming and wondered if it was like my 12 GS i needed to replace the OEM stuff?
Old Feb 2, 2015 | 09:21 AM
managerman's Avatar
managerman
I do not believe they are. I just replaced mine this weekend with Carbotech 1521's...Mainly due to excessive brake dust from the OEM pads
-M
Old Feb 2, 2015 | 01:40 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
-M
Elmer
Old Feb 2, 2015 | 01:54 PM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
The Z51 does not have Ceramic pads. If you are looking to minimize your brake dust and not tracking the car switch to the Carbotech 1521. We have some in stock and more coming every week. Give me a call at 216-780-8825 to order.
F: $170 R: $173 Less 5% forum pricing.
Carbotech™ Bobcat 1521™ The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
Old Feb 2, 2015 | 05:05 PM
Gold Z's Avatar
Gold Z
Veteran: Marine Corps
I also swapped my stock pads for the Carbotech Bobcat 1521 pads. That ended my dust problem. I highly recommend them.
Old Feb 2, 2015 | 05:12 PM
0v3rc10ck3d's Avatar
0v3rc10ck3d
So what if you do plan on taking it to the track? Keep the stock pads or is there another Carbotech option?
Old Feb 2, 2015 | 05:35 PM
Carbotech Adam
Supporting Vendor
Carbotech makes several track pad options and the beauty with Carbotech is all there compounds are compatible with each other so. you run the 1521 on the street and than step up to the XP series for track days. All you would have to do is swap pads and go. No re bedding of the pad, no cleaning of the rotors put them on and go.
Compounds list is below. If you are interested please call me at 216-780-8825 and we can discuss what compound fits your needs.
Carbotech™ 1521™
The Carbotech™ 1521™ is our high performance street compound. The 1521™ compound is known for its release and modulation, along with unmatched rotor friendliness. 1521™ is also a very low dusting and low noise compound with an excellent initial bite. This compound's excellent linear torque production provides incredible braking force without ABS intervention. Carbotech™ 1521™ operating range starts out at ambient and goes up to 800°F (426°C+). 1521™ is suitable for ALL street cars, perfect for your tow vehicle or fleet vehicle. Carbotech™ 1521™ is NOT recommended for ANY track use.
Carbotech™ AX6™
The AX6™ is specifically engineered for Autocross applications. A high torque brake compound delivering reliable and consistent performance over a very wide operating temperature range of 50°F to 1000°F + (10°C to 537°C+). The advanced compound matrix provides an excellent initial bite, high coefficient of friction at lower temperatures along with very progressive brake modulation and release characteristics. Many drivers use the AX6™ for street driving as well, even though Carbotech™ doesn't recommend street driving with AX6™ due to possible elevated levels of dust and noise. AX6™ is NOT recommended as a race compound in most applications.
Carbotech™ XP8™
A high torque brake compound with a wide operating temperature range of 200°F-1250°F+ (93°C to 676°C+). Carbotech™ XP8™ is the first of our racing compounds. Good initial bite at race temperatures, high coefficient of friction, excellent modulation and release characteristics. Extremely high fade resistance and very rotor friendly. Perfect for track day use with any tire and can still be driven safely to and from the track. Carbotech™ does NOT recommended XP8™ as a daily driven street pad due to elevated levels of dust and noise. Carbotech™ XP8™ is a great compound on the front & rear of most open wheel and sports racers.
Carbotech™ XP10™
When Carbotech™ unleashed the XP10™ to the general public it immediately gathered multiple regional, divisional, and national championships. The XP10™ has a very strong initial bite with a coefficient of friction and rotor friendliness unmatched in the industry. Fade resistance is in excess of 1475°F (801°C). XP10™ still maintains the highly praised release, excellent modulation and rotor friendliness that have made all Carbotech™ compounds so successful. Carbotech™ XP10™ is not recommended as a daily-driven street pad due to possible elevated levels of dust and noise.
Carbotech™ XP12™
Another highly successful XP™ series compound with an excellent initial bite, torque and fade resistance over and above the XP10™ compound. XP12™ has temperature range of 250°F to 1850°F+ (121°C to 1010°C+). The XP12™ has that excellent Carbotech™ release and modulation that has made all other Carbotech™ compounds so successful. The XP12™ is more rotor aggressive than XP10™, but compared to the competition the XP12™ is still very rotor friendly. XP12™ is NOT recommended for use as a daily driven street pad due to possible elevated levels of dust and noise.
Carbotech™ XP20™
The latest iteration of the highly successful XP™ series of compounds. XP20™ is a step up from the highly successful XP16™ compound. With an extremely aggressive initial bite, linear torque curve and excellent fade resistance the XP20™ is another major step in progression of the highly successful XP™ series line of compounds from Carbotech™. XP20™ has a temperature range of 275°F to 2000°F+ (135°C to 1093°C+). Carbotech™ XP20™ maintains our tradition of having the outstanding release and modulation that has made all other Carbotech™ compounds so successful. Carbotech™ XP20™ is NOT recommended for use as a daily driven street pad due to possible elevated levels of dust and noise.
Carbotech™ XP24™
XP24™ is the pinnacle compound of the extremely successful XP™ Series of compounds engineered by Carbotech™. This compound is based on the same fundamentals that exist in all other Carbotech™ formulations. XP24™ has even more initial bite, more overall bite, and more torque along with the most linear torque curve we have ever offered. The thermal characteristics are of the highest Carbotech™ offers along with one of the highest coefficient of friction ratings offered by anyone in the braking industry. This compound is the longest wearing compound Carbotech™ offers as it was originally engineered for endurance applications at the highest pro racing levels. This revolutionary new compound has been extremely successful with open wheel, closed wheel, sprint and endurance applications. XP24™ has a temperature range of 400°F to 2000°F+ (204°C to 1093°C+). Carbotech™ XP24™ is NOT recommended for use as a daily driven street pad due to possible elevated levels of dust and noise along with the necessary heat required to work properly.
Carbotech™ RP2™
The RP2™ compound was engineered for endurance racing based on our highly successful XP™ Series formulations. RP2™ has strong initial bite, a little less modulation than our XP12™, but still maintains the rotor friendliness of our XP™ series compounds. RP2™ has great fade resistance with a temperature range of 250°F to 1450°F+ (121°C to 787°C). RP2™ is as rotor friendly as our XP™ series compounds. Carbotech™ RP2™ is NOT recommended for use as a daily driven street pad due to possible elevated levels of dust and noise.
Old Feb 3, 2015 | 10:36 PM
hdwideglide's Avatar
hdwideglide
I had mine installed before I took delivery. These pads are awesome. Thanks Adam!!
Old Feb 3, 2015 | 10:52 PM
scottjays's Avatar
scottjays
go with the carbotech, you will be eternally happy
Old Feb 4, 2015 | 09:18 AM
Carbotech Adam
Supporting Vendor
No problem
Old Feb 4, 2015 | 04:52 PM
badhabit_wb's Avatar
badhabit_wb
Adam is the performance better with the bobcat's or just less dust? can you autocross with these pads? I'll be using them on my z06, thanks
Old Feb 4, 2015 | 05:10 PM
W88fixer's Avatar
W88fixer
Perhaps this is a difficult question to answer but how do you think stopping distances would compare between the base model pads and the 1521s when cold? Thanks
Old Feb 4, 2015 | 09:25 PM
Carbotech Adam
Supporting Vendor
Yes, this pad can be used for Auto X. Not HPDE events. Performance on the street should be the same. Under thresh hold braking you may find more bite in the 1521.
Old Feb 4, 2015 | 09:27 PM
Carbotech Adam
Supporting Vendor
This pad will out brake the base C7 pad. The 1521 is ceramic based but, also contains carbon and Kevlar. Stock C7 base pad is full ceramic to my knowledge.
Old Feb 5, 2015 | 09:57 AM
W88fixer's Avatar
W88fixer
Thanks for the quick reply. Don
To 2015 C7 brake pads
