810whp dyno video, built by Boost Works...
https://www.youtube.com/watch?v=ehDc...ature=youtu.be
The car came out great.. Has our 1000s package, with a few additional upgrades. We had a nice set of wheels made for it, and the customer added a set of skirts/front splitter.
Here's a mod list:
Boost Works assembled 416ci short block (10:1 C/R)
CNC ported heads
Titanium retainers, and PAC Alloy springs
LMR tool steel cam with 38% fuel lobe
ARP head studs/ARP main studs/Side bolts
Texas Speed HD pushrods
Comp Trunion kit with ARP rocker bolts
Cometic MLS head gaskets
Modified Clevite H series LSx bearings
ECS 1500 kit
LMR catch can
McLeod RXT clutch/flywheel
American Racing 1 7/8" LT's with 3" x-pipe
Devil's Own single nozzle methanol kit
Stock dual mode mufflers
Custom True Forged 3 piece wheels, 20 x 11 and 20 x 9
Toyo R888 (rear)
Michelin Pilot Sport (front)
Side skirts and front splitter
Blacked out badging
Boost Works C7 1000s Badging
The car was tuned by Steven and Jason over at LMR. We've enjoyed working with these guys, and they definitely know their stuff when it comes to tuning these cars.
We'll get a fuel system in place, and see what we can make with the Novi 1500. I think the record is upper 800's. The in-tank pump is maxed out at an HONEST 810whp. That's about the limit on this particular dyno with the stock in-tank pump, and no trickery.
My (very reproducible) 893whp is on the stock fuel pump, a 35% fuel lobe cam, 93-octane, and a dual-nozzle Alky system with a relatively-similar setup to this car.
I think that's about tops for the 1500, but we would have still had a little room to go higher on the stock pump with a 2200r (but not much, obviously).
I might have just read into it wrong, so please don't take offense. I was just a bit curious about that part.
Side note: I wish I had that clutch/flywheel in mine.
Just meant that it was made without any assistance of nitrous, crazy/unrealistic timing, or anything like that. That's a good number for this particular dyno, which reads a little lower than most. To top it off, we were making that number at 6200rpm. So, we were proud to get that. Most cars max out at around 800whp on this particular dyno with the stock in-tank pump.
I'm interested to see what we make when we get a solid fuel system in the car. I think we'll see 850-875whp on LMR's dyno with a better in-tank pump.
Your car makes pretty sick power!
Just meant that it was made without any assistance of nitrous, crazy/unrealistic timing, or anything like that. That's a good number for this particular dyno, which reads a little lower than most. So, we were proud to get that. Most cars max out at around 800whp on this particular dyno with the stock in-tank pump.
I'm interested to see what we make when we get a solid fuel system in the car. Your car makes pretty sick power!
I know what you mean about 'suicide' / crazy timing dyno runs, though - seen a fair bit of those, and it's never fun for the owner.
I'm also interested in seeing what the upgraded fuel pump allows for - regardless of the dyno numbers, the scaling will be the indicator. I had mine finished up right before the LT4 pump became available. Always something bigger and better coming out... Ahh, toys.
With the 38% lobe, and a spring, I think we should be good to over 1000whp. Eventually, the car is getting the head unit upgrade, so I think with the lift pump upgrade, we might see 1050 or so. Seems to be the norm for that combo. The car is stupid fast as it sits. My buddy was dead nuts even with a 1000RR bike the other day. That's a high 9 second bike. So, the car feels just about right at the power it's making.
Always something upgrade.. It's never "finished".
The looks you get when you stick with, or pull on a liter bike, priceless!
Steven Fereday
FIRST C7 Corvette in the 7's & 9's
Current C7 World Record Holder 7.55 @ 184 MPH
Quickest and Fastest GEN5 LT Powered Vehicle
LMR1200HP Supercharged C7 8.84 @ 160
LMR1200HP Twin Turbo C7 9.35@155mph-2014
2 TIME OUTLAW DRAG RADIAL LSX CHAMPION 2008/2010
9.47 ZR1 Corvette-2009
LATE MODEL RACECRAFT
713-466-9900
LateModelRacecraft.com
Too many PMs, please call or email instead, thanks!
Nice and flat all the way up!
