Start it up or let it sleep
Old Feb 15, 2015 | 12:40 PM
jdf14's Avatar
jdf14
Default Start it up or let it sleep
First, if this has been discussed previously pardon, I did a search and could not find anything.
So My C7 Z51 has been sitting for a couple of months now, (winter on Long Island has been cold this year). So, should I let it remain without starting or start it up and let it run. I have the battery charger option and keep it plugged in, the car is covered, and on those ramps that avoid flat spots; kept in an attached garage that is not heated. So what do you guys suggest?
thanks
Joe
Old Feb 15, 2015 | 12:46 PM
PARANORMAL's Avatar
PARANORMAL
SUPPORT AUTISM
St. Jude Donor '10, '14
Keep it charging, keep it covered and let it sleep.
Old Feb 15, 2015 | 01:00 PM
Rob Willis's Avatar
Rob Willis
Yep, let it sit.
Old Feb 15, 2015 | 01:01 PM
jim2092's Avatar
jim2092
Veteran: Marine Corps
St. Jude Donor '08
Short drives (short start ups) create more contamination in the oil than long trips. No contamination when not running.
Old Feb 15, 2015 | 01:29 PM
jdf14's Avatar
jdf14
Default thanks ALL
Thanks guys,
I was thinking that it should sleep, due to the condensation in muffler etc., so my thinking is confirmed.
I appreciate your responses.
Joe
Old Feb 15, 2015 | 08:03 PM
MitchAlsup's Avatar
MitchAlsup
Unless you are going to start it up and let it get all the way up to temperature, and then hold it at temperature for 20-30 minutes, then just let it sleep.
Old Feb 15, 2015 | 08:09 PM
John Ulrich's Avatar
John Ulrich
Sleep.
Old Feb 15, 2015 | 11:52 PM
Papas02C5's Avatar
Papas02C5
My C7 has been asleep since mid Sept and will not awaken until late May. I always let my C5 sleep for long periods also with no issues what so ever.. Just use a battery tender, wash and wax before covering with a good car cover and fill up gas tank and add StaBil..
Old Feb 16, 2015 | 01:24 AM
jdf14's Avatar
jdf14
Yup did all that, in fact I used the new stuff that releases vapor above the tank. I wasn't sure if "fogging" the engine, (what is done to boat engines - adding oil into each cyl, was necessary). I never heard of anyone doing that but, I just wanted to be sure.
thanks
Old Feb 16, 2015 | 07:16 AM
Itshakes's Avatar
Itshakes
WOW! You mean to tell me that your car is not used for 8 months? I admire your ability to not have the "Corvette" fix for that long. Our car sits for 3 months and by the end of February I get antsy to drive it.
Old Feb 16, 2015 | 08:58 AM
NSC5's Avatar
NSC5
I agree with sleep also unless you can get all of the fluids up to temperature. Change oil right before its winter hibernation. If possible to find in your area use non-ethanol fuel for the last few tanks before storage. Alcohol is highly hygroscopic and "corn fuel" does not age well and is prone to forming gummy deposits. Second best solution is to treat with stabilizer well before storing to make sure stabilized gas is used throughout the fuel system and this should be done even with good, no corn, fuel.
Old Feb 16, 2015 | 09:54 AM
Waytofastvette2006's Avatar
Waytofastvette2006
I always start mine up every couple months during the winter. I let it run at least 20 min or so.
Is it good for it or necessary? I have no idea but it makes me happy sitting in it and revving the motor a few times haha ( after its warm of course )
Old Feb 17, 2015 | 09:37 PM
Papas02C5's Avatar
Papas02C5
Yes unfortunately this is the case. I work overseas in Dubai and I only get to drive it when I go home on vacation. I have considered shipping it over here but thought better of it. Now when I go home I REALLY enjoy opening my garage door..
Old Feb 18, 2015 | 02:25 PM
Johniorio4's Avatar
Johniorio4
I admire you for not being able to drive it for so long! I cannot go a day without driving mine
Old Feb 20, 2015 | 05:26 AM
Supermassive's Avatar
Supermassive
Not gonna lie, my C7 sleeps a day maybe two tops. I take daily driving my C7 literally as its my primary mode of transportation. Kudos to those who can actually wait to drive, but I'm sure I's be one of those nutjobs driving in the snow
Old Feb 20, 2015 | 09:42 PM
bob guzzy's Avatar
bob guzzy
I let mine sleep but if I'm working near the car, I disconnect the charger start it up run it until I think all the moisture is out of it.
I run the heat first then the ac, it's good to let the compressor run in the winter.
Old Feb 20, 2015 | 10:13 PM
Vegas1500's Avatar
Vegas1500
In the same boat but only due to our long Canadian winters.....it does suck but absence makes the heart grow fonder..
Old Feb 22, 2015 | 12:57 PM
Bucknut2006's Avatar
Bucknut2006
Mines being sleeping over a week and the weather doesn't appear to be improving until late this week Would cry if I had to actually put it away for the entire winter.
To Start it up or let it sleep
