C7 Manual Shifter: Really that Bad?
Old 02-17-2015, 10:50 AM
  #41
Bunk
Bunk's Avatar
Perfect shifter. Just the way it should be.
911Hunter (12-26-2022)
Old 02-17-2015, 11:02 AM
  #42
Kracka
Kracka's Avatar
Received 5,760 Likes on 2,942 Posts
Originally Posted by RussM05
The stock rubber mounts have vibration bushings that wear out pretty quickly. I you want to replace them, ZIP sells the urethane bushings but I recommend the aftermarket rubber bushings available from West Coast Corvette, JW Motoring, or eBay. They are larger than stock so when you tighten down the mounting bolts, they are stiffer than stock.
Thanks for the info! Do the polyurethane bushings transmit too much vibration, is that why you prefer the enlarged rubber version?
Rubber bushings: http://shop.jwmotoring.com/C5-C6-COR...?categoryId=-1
Polyurethane bushings: http://www.zip-corvette.com/catalog/...sing-bushings/
Also, what do you think of something like this? Would it potentially remove some play/slop in the stock mechanism (I'm assuming it'll fit the C7, correct me if I'm wrong please)? What I'd really like to see is one made of Delrin. http://www.ebay.com/itm/1997-up-C5-C6-Z06-ZR1-Corvette-T56-TR6060-bronze-shifter-cup-isolator-bushing-/251719793242?pt=Motors_Car_Truck_Parts_Accessories&hash=item3a9bab3a5a&vxp=mtr
Old 02-17-2015, 02:09 PM
  #43
Zip Corvettes
Platinum Supporting Vendor
Zip Corvettes's Avatar
Also, what do you think of something like this? Would it potentially remove some play/slop in the stock mechanism (I'm assuming it'll fit the C7, correct me if I'm wrong please)? What I'd really like to see is one made of Delrin. 1997 Up C5 C6 Z06 ZR1 Corvette T56 TR6060 Bronze Shifter Cup Isolator Bushing | eBay
The shifter makes a big difference. The stock one is good, but the aftermarket is better. It has a much tighter feel to it than the stocker.
As far as the bushings, we made them out of poly for a reason. The rubber one that you see has a softer durometer than the stock one does and that is the wrong direction to go. It is also molded round, not oval like the original. We were offered that bushing as well to sell and decided that since it was not correct at all we would make the correct one since you can't buy the factory bushing. The Z car had a solid one and they also are great, so we went with a high durometer polyurethane that is made for us by energy suspension.
Old 02-17-2015, 02:10 PM
  #44
Zip Corvettes
Delrin would have to be machined since it is an oval shape and the step in it. I think it would be very expensive if done in Delrin.
Old 02-17-2015, 02:22 PM
  #45
Kracka
Kracka's Avatar
Thank you for the feedback, Energy makes quality pieces! Have you found any noise or vibration issues switching to polyurethane? Any chance you've had some made in black vs. red?
Old 02-17-2015, 08:37 PM
  #46
Fisyfish
6th Gear
Fisyfish's Avatar
Originally Posted by TXArtic
My only complaint is that it requires more effort to shift when the vehicle is cold. Once everything warms up the shifting is quick/smooth, the throw is pretty short too. I am happy with the M7.
same experience I have but just takes a few minutes to warm up and then is fine
Old 02-18-2015, 01:23 PM
  #47
jwbert
jwbert's Avatar
Default Stock vs MGW
Although it was probably my technique and lack of familiarity with
the new C7 shift feel, I missed the 2 to 3 shift several times while
running on track at Spring Mountain. When I got home and into my own car again, it also happened to me once on track, so I installed the
MGW (I had had one in my C6 Z06) and have not experienced the same 2 to 3 problem since. By no means an all encompassing test,
just my feel for it. The MGW gives me a more confident feeling.
Old 02-18-2015, 02:16 PM
  #48
Johniorio4
Johniorio4's Avatar
I love the shifter. Much better than my previous e92 m3 6 mt.
Old 02-18-2015, 02:51 PM
  #49
Zip Corvettes
I don't have any plans of making them in black right now. We chose the red because of energy suspension and I wanted them to be seen as being different. You can't see them once they are in the car though.
Old 02-18-2015, 02:57 PM
  #50
Kracka
Kracka's Avatar
Makes sense. Before I order, any vibration/noise issues to be aware of/expect after installation?
*edit*
I read a few favorable reviews so I went ahead and placed my order through your website.
  #51
Zip Corvettes
If you are going to put a shifter in a C7 you really need to use the bent shaft. It has a 15 degree bend on it. While the straight one will work, I noticed that the shift pattern on the C7 changed as far as the angle on which it is on the ****. You cant see any of the forward gears unless the shifter is pulled all the way back. NOW I know you don't or should not look down to make your shift but it is a little detail that bothered me. Attention to the little things makes the bigger things even nicer.
Old 02-18-2015, 08:29 PM
  #52
rob03zo6
rob03zo6's Avatar
Got mine today
Old 02-19-2015, 02:35 PM
  #53
TNSQUIRE
TNSQUIRE's Avatar
Is there a C7 owner in San Diego who has the MGW shifter installed. I would like to see it and feel the difference. Feel free to PM me. Thanks
Old 02-19-2015, 06:01 PM
  #54
CorvetteTony2008
CorvetteTony2008's Avatar
I added a Hurst short throw shifter to my '08 Vert and after 6 months put the stock shifter back in; it was hard to shift and downshifting was a struggle. I love the shifter in my '15 Z51.
Old 02-19-2015, 06:13 PM
  #55
CorvetteTony2008
I forgot to say how badly the Hurst shifter vibrated and rattled; I contacted Hurst tech center and the reply was "they all do that".
Old 02-19-2015, 06:19 PM
  #56
BillB3672
BillB3672's Avatar
Default MGW make the best shifter in my opinion
I love the look!
I had a MGW shifter in my 2010 Z06, it is a great shifter! Positive shifting and no rattling or noise, that is because of all the quality control, and testing before they are released to the public!
Originally Posted by rob03zo6
Got mine today
Old 02-19-2015, 06:41 PM
  #57
rob03zo6
rob03zo6's Avatar
I agree, The Hurst shifter was junk. The MGW is a quality shifters.
To C7 Manual Shifter: Really that Bad?
Old 02-19-2015, 06:50 PM
  #58
tkbigsky
tkbigsky's Avatar
That's why you go with a precision manufacturing company like MGW and not Hurst. There is zero rattle or movement in my MGW and all shifts are positive and quick. Again the stock shifter and primarily the transmission are a huge improvement by GM but, if you really want to jump through gears MGW is the way to go. I left the stock **** on so the install is clean and stock looking.
Old 02-20-2015, 05:25 PM
  #59
daytonagary
daytonagary's Avatar
love the stock shifter just as it is..............
Old 02-22-2015, 08:39 AM
  #60
stephen1254
stephen1254's Avatar
Originally Posted by ckwhite
I've read lots of earlier posts that praise the performance and ease of installation of the MGW short-throw shifter. My question is: is the stock C7 shifter really that bad? - on a brand new"state of the art 7-speed? Is this something I honestly need to think about budgeting for? (Yeah, obviously I don't have my car yet and haven't test driven a manual.)
Having installed my MGW shifter yesterday, I think the best way to answer this question is to say that, as good as the stock shifter is, the MGW shifter is significantly better. It eliminates any vagueness in the stock shifter.
Another way of looking at this is when you look at the areas of the car that really contribute to the driving experience, the brakes, steering, shifting, acceleration, and handling, changing out the shifter is about the least expensive improvement you can make.
For me, the MGW shifter really completes the entire package. The car, especially between 3500 RPM and 5000 RPM, has ferocious acceleration. The brakes are easy to modulate and feel very solid. The steering, while lacking some of the feedback you would get from a hydraulic system, is very precise - it is very easy to point the car right where you want it. The car is very well balanced and the handling limits are very high. With the MGW shifter the shifting is now as precise as the rest of the car.
Quick Reply: C7 Manual Shifter: Really that Bad?
