C7 track use catch can--which one?
Old Feb 21, 2015 | 08:36 AM
vettenutchas's Avatar
vettenutchas
Default C7 track use catch can--which one?
I have a C7 with the Z51 option that I will be taking to HPDE days and some Autocross--any one doing the same and using an oil catch can? What brand and model are you using and are you satisfied with its performance? Any and all info appreciated!! My C7 is a 2015 if that makes any difference.
Old Feb 22, 2015 | 10:06 AM
leadville1's Avatar
leadville1
I bought the UPR catch can, for my Z51. It comes with the clean side seperator as well. It is a great kit, easy to install and the braided hose lines with quick connects are neatly made.
I would highly recommend it.
http://www.uprproducts.com/chevy-bil...rvette-14.html
Old Feb 22, 2015 | 02:07 PM
ilivas's Avatar
ilivas
This is my first vette, but I've always been a car guy mostly with high hp turbo cars. A catch can is literally just a reservoir with some hoses. I don't see the need in spending a ton of money. I've seen 700whp turbo subarus with a mason jar and some fuel lines.
I understand aesthetics has something to do with it, so I think I'll probably end up getting this and sticking some steel wool in it so the oil has something to stick to. It looks nice enough.
Amazon.com: Godspeed Universal Racing Oil Catch Can Tank Oil Reservoir Tank Black Color: Automotive Amazon.com: Godspeed Universal Racing Oil Catch Can Tank Oil Reservoir Tank Black Color: Automotive
Old Feb 22, 2015 | 10:25 PM
EcoBrick Bob's Avatar
EcoBrick Bob
Dazed Confused & Verklemp
I too have the UPR with the clean oil separator on my Z51. This was my first MOD!!!!... If you have a dry sump Vette... a simple catch can won't solve your blow by from all the posts I've read.
A catch can is always a good investment, but with DI engines, it's a necessity. On my non- DI G8(s) ( have 2) I get an ounce of oil in the catch can per 2K mi in stop and go driving. In a DI engine, there is no fuel spray on the intake valves to clean them, which means that the oil residue on them builds up and cakes on with heat.
Audi DI engines have had many issues with the cake that builds up on the intake valves and then causes the air flow to be limited, disrupting the normal Air/ Fuel ratio.
Been there with my DI Ford EB Flex.... Going to protect my new VY Z51 Vette!!!!!
Old Feb 22, 2015 | 10:30 PM
ilivas's Avatar
ilivas
Why is that? Not trying to argue... I'm genuinely curious.
Old Feb 22, 2015 | 10:54 PM
Higgs Boson's Avatar
Higgs Boson
what he means is that it will help with blow by but it will not help with dry sump puke issue.
Old Feb 22, 2015 | 11:05 PM
ilivas's Avatar
ilivas
What does the expensive catch can have, that a regular catch can doesn't have?
Old Feb 23, 2015 | 07:12 AM
leadville1's Avatar
leadville1
I would be careful using steel wool as a catch all for blow by in a catch can. I did this in My M3 and it caused all kinds of havoc. My car started burning oil and the system would clog up. I took out the steel wool and Voila my problems were solved.
I would say the reason for the cost of the UPR is the quality with which it is designed and finished, It uses quick connect hoses that are custom made for the application, and the clean side separator which I haven't seen in other versions of catch cans.
Believe me I choked a little too on the price of this catch can but in the end I believe the engineering, fit and finish make it worthwhile.
Old Feb 23, 2015 | 09:27 PM
ilivas's Avatar
ilivas
If it's me, I'll just spend $20. I understand that fit and finish can fetch a premium. To many, that's worth the price of admission. In my case, if they do the exact same thing, I'll go with the $20 option instead of the $300 one.
I'm still in sticker shock for price of mods of this car compared to others. Corvette parts are not cheap. Many parts are 4 or 5 times the price of what I'm used to.
Old Feb 23, 2015 | 09:37 PM
leadville1's Avatar
leadville1
I am coming from the other direction, I modified several BMW's these cars are so cheap to work on. I was amazed at how inexpensive parts are for this car. The two things I bought that seemed high were the UPR catch can and the ATI crank pulley, other than that things are fairly cheap.
Old Feb 23, 2015 | 09:48 PM
ilivas's Avatar
ilivas
I had an STi before this. For the price of a Corvette intake, headers, ems, and full exhaust, I could almost get mods to make a 600+whp daily driven STi. That's what's blowing my mind, I had a 700whp twin fuel pump, STi that was knocking on the door of 9's in the 1/4 mile, and I had a cheap ebay $20 oil catch can, and it worked well. With that being said, I love my c7, and it's a blast to drive still.
Old Feb 24, 2015 | 06:20 PM
sahlbom's Avatar
sahlbom
I've been researching the CC options for weeks. Just placed an order for the Mighty Mouse Solutions PCV catch can, based primarily on some C6 Z06 forum posts. This can features a one-way breather to prevent crankcase pressure at WOT. It also uses an upgraded PCV valve mounted on the CC.
I don't currently have any oil from the dry sump tank in the air box, but have wiped out the intake manifold area twice now.
I may add a second "draft" can to clean up oil burps from the sump tank in the future, if it becomes a problem.
To C7 track use catch can--which one?
