Intake manifold removal help needed
Old Feb 21, 2015 | 10:27 AM
Kracka's Avatar
Kracka
Default Intake manifold removal help needed
I'm stumped by the red pressure fit collar on the drivers rear of the manifold. Anyone have tips or advice? Thanks!
Old Feb 21, 2015 | 10:56 AM
Kracka's Avatar
Kracka
Got it, very simple actually! Press the red collar into the manifold then gently pull back on the hose. It will then slip right out.
Old Feb 21, 2015 | 11:01 AM
Higgs Boson's Avatar
Higgs Boson
now you got your keyboard dirty
Old Feb 21, 2015 | 03:14 PM
Kracka's Avatar
Kracka
Just my phone screen
Old Feb 21, 2015 | 03:31 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
I was stumped by this too for a few minutes when I took mine off. I did the same thing you did by happenstance to get it off lol
Old Mar 5, 2015 | 10:52 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Jut to confirm as I and at that point of the dreaded red collar---
What do you mean by pushing the collar INTO the manifold ??
Do you mean push the collar TOWARDS the manifold side ?
OR simply push on the collar
If you mean push it towards the manifold--will a skinny screwdriver do it or do I need the plastic tool that pushes it more around the whole red collar ??
Old Mar 6, 2015 | 08:18 AM
Kracka's Avatar
Kracka
The harder the hose is pulled, the tighter the red collar grips. Gently push the hose towards the intake manifold and the red collar should loosen up enough to push it in (towards the intake manifold) either by hand or with a small screwdriver. Think of it as a Chinese finger trap
Old Mar 6, 2015 | 08:34 PM
tblu92's Avatar
tblu92
Thanks got it off this morning---just didn't want to break anything---
Inside of intake was oily shiny but no oil film on your fingers when rubbing-- Hoping this is OK as I do have a UPR catch can---With the stock PCV do you know how oily the LT gets ????
-Mine had a horrible mismatch at the seams !! especially on the floor of the intake--On the top there is a 2nd seam further back that I couldn't reach with my porting tools and looks like it will have to be hand blended----I am doing it myself as I've mildly ported many LS intake before---
Old Mar 7, 2015 | 09:48 AM
Kracka's Avatar
Kracka
Regarding the oil sheen, yours sounds about the same as mine, but I don't have a catch can.
To Intake manifold removal help needed
