Tuning question.
Old Mar 5, 2015 | 06:51 PM
Dangerous Don's Avatar
Dangerous Don
Default Tuning question.
If I were to get my car tuned, say using hptuners, is there any way to revert the car back to stock so that the dealer wouldn't know it was previously tuned?
Old Mar 5, 2015 | 07:16 PM
Kracka's Avatar
Kracka
No, you'd need to tune with Diablo for that.
Old Mar 5, 2015 | 07:17 PM
Dangerous Don
Am I able to custom tune with the Diablo like I can with hp, or is it just preset tunes?
Old Mar 5, 2015 | 07:53 PM
Higgs Boson's Avatar
Higgs Boson
A custom tune can be created if you are near a dealer/tuner for Diablo. If not, they can try emailing logs and tunes back and forth.
HPTuners is more ubiquitous.
Old Mar 5, 2015 | 08:52 PM
Dangerous Don
So would y'all suggest the Trinity or the intune?
Old Mar 6, 2015 | 08:23 AM
Kracka's Avatar
Kracka
I use the InTune, and do have a custom tune on it from DiabLew (MonteSS on this forum). The tunes are the same between the InTune and Trinity, it's just the extra features that set them apart. I personally wanted the smaller size rather than the extra features.
Old Mar 6, 2015 | 08:24 AM
11B250's Avatar
11B250
intue seems to be the way to go. it's also more affordable. as of now, both are undetectable
Old Mar 6, 2015 | 09:02 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
It sort of depends on your intended future mods---If you are going to leave it basically stock then a handheld should be OK---Diablo is the best of the handhelds
The next level of tuning is with HP or EFILIVE --Difference being that even Diablo has limited access to ALL the tables in your tune which need addressing with major mods
HP Or EFILVE has access to approx. 450 tables in the engine file and about 500 in the trans file----Hyper. or Superchps maybe 50 tables and Diablo has the most-of the handhelds ----
Old Mar 6, 2015 | 10:25 PM
Dangerous Don
Yes the eventual plan is the 3 hit combo, ecs + arh + meth. So with that being said I plan on first going with the arh until I save a few more pennies for the ecs and meth. So as far as right now I should be good with the Diablo and see about getting a custom tune for the addition of th arh, but once I move on to the ecs and meth it would be recommended to tune with hpt?
Old Mar 7, 2015 | 08:45 AM
jyounger74's Avatar
jyounger74
Diablew can do a custom tune for you
http://www.diablewtune.com
Old Mar 7, 2015 | 11:00 AM
11B250's Avatar
11B250
Perhaps this is why diablosport can't be detected. it doesn't touch the tables that changes the hex number or whatever it's called CTN or something
Old Mar 7, 2015 | 04:09 PM
Dan4time's Avatar
Dan4time
Default Very happy with the Diablo Intune...
I am very pleased with the added performance of the Diablo Intune. I didnt want to void my warranty, so I went with the Intune. It shuts off the torque management system so the cars acceleration is immediate, made a huge difference, plus you can calibrate the throttle sensitivity, another winner since it is a drive by wire system. I have an automatic, so I went to the firm shift. I definitely feel a stronger "seat of the pants" acceleration. I even get a couple extra miles per gallon. Very well worth it, and you wont blow your warranty. It truly wakes up the C7!
Dan
Old Mar 7, 2015 | 10:26 PM
tblu92's Avatar
tblu92
The issue with tuning the new E92 GM computers is that it has been reported that after tuning with some handhelds and even HP/EFILIVE that the tune will change the "checksums" in your stock tune- Most dealers and smog shops don't even know what checksums are and they are overlooked--As of today I believe that that issue has been resolved by the tuning software companies so really a non issue anymore--
To Tuning question.
