Did I break the auto rev matching function?
Old Mar 11, 2015 | 12:23 AM
Johniorio4's Avatar
Johniorio4
Default Did I break the auto rev matching function?
Hello everyone, on my way home tonight I attempted a simple downshift from 3rd to 2nd with the feature on, but as I engaged second the amber color of the gear changed to white and the downshift was not rev matched. I definitely did not flick the paddles. Now, the car feels a bit strange as I accelerate in 1st up to about 3000 rpm. It sounds a little different but it is hard to explain. Did I blow my clutch? I'm only at 6000 miles on my 2014 7mt, and I have never even gone to the track with this car. What the hell is going on? lol
Old Mar 11, 2015 | 02:09 AM
CDH76's Avatar
CDH76
Do you see a white dash. where gear indicator is at? Did you some what miss the gear or take too long to shift?
A gear indicator in the instrument
cluster displays the current gear
selected:
. When ARM is activated, the
gear number is amber.
. When ARM is deactivated, the
gear number is white.
. A white dash indicates that
service is required. ARM will be
disabled, and the malfunction
indicator lamp will be on. See
Malfunction Indicator Lamp on
page 5-15. The clutch and
manual transmission will
continue to operate normally.
ARM will also:
. Be active above 32 km/h
(20 mph).
. Match engine speed up to
5400 rpm.
. Not operate when the
accelerator pedal is applied.
. Be disabled when the coolant
temperature is below 0°C (32°F).
Old Mar 11, 2015 | 12:54 PM
Johniorio4's Avatar
Johniorio4
I didn't miss the gear at all or take too long to shift. As soon as I put the car in second the amber color around the gear indicator switched to white and the downshift was not rev matched so it was extremely bumpy.
Old Mar 11, 2015 | 09:31 PM
Greenkirby21's Avatar
Greenkirby21
I don't think it rev matches downshifts below 20 MPH. I make sure to shift to second before hitting 20 MPH
To Did I break the auto rev matching function?
