AFE + TB + Corsa + DiabLew =
Old Mar 15, 2015 | 10:54 AM
dovervold's Avatar
dovervold
Default AFE + TB + Corsa + DiabLew =
SUCCESS!!! For any of you on the fence about where to go with mods and still have a warranty, this is your ticket. For under $2,000 you can really wake up your Stingray. Stock, I was a little bored, even whining to the wife about the performance of my 2014 Z51 M7.
So, added an AFE, Ported TB, Corsa X-pipe, and Diablo 93 AFE Intune. Car sounded better, performed better, and pulled much better then stock.
Next, I did the required logging required by Diablew so he could work his magic, and in less the 24 hours had a new tune sitting in my in box. Loaded it into the car Friday, and BAM, another big step forward. Tip in instant, and never stops pulling. 1st and 2nd are an absolute blast, and where as before 3rd gear felt a little sluggish, it now pulls hard all the way to 4th.
And the Corsa double X pipe really adds some noise, in a good way. My car is NPP, and it sounds really aggressive.
I was looking at Centri and h/c packages, but struggled with throwing a brand new warranty out the window. Now with some simple bolt ons you can go to the next level and keep your warranty...
Old Mar 15, 2015 | 02:03 PM
Darken's Avatar
Darken
8th Gear
This thread would be better with static technical specs instead of speculative seat of the pants dyno results. We all know those mods will increase responsiveness and horsepower overall, but most want to see dyno results or some back to back timed runs as indirect improvement levels good choice on the mods.
Old Mar 15, 2015 | 08:50 PM
Kracka's Avatar
Kracka
Great combo! Mine is similar and I love it
Old Mar 15, 2015 | 09:10 PM
dovervold's Avatar
dovervold
Thanks Kracka, learned a lot from your threads. Temped to do the ported and coated exhaust manifolds, and maybe a intake too!
Old Mar 15, 2015 | 09:18 PM
Kracka's Avatar
Kracka
Sounds good! I'll be selling my Fasterproms ported intake manifold soon, and have some stock exhaust manifolds available if you need them for porting.
Old Mar 15, 2015 | 09:53 PM
11B250's Avatar
11B250
Wish there were some dyno numbers to go with it! I hear diablo tunes are really felt because the throttle progression is much higher.
and how does the x pipe install? is there a stock xpipe there? H pipe? cats can stay in place?
Old Mar 16, 2015 | 09:39 AM
dovervold's Avatar
dovervold
Factory X-pipe has a second set of cats at the front of the pipe. Corsa's don't so you have a nice straight 3" pipe with double helix (it has 2 X sections). You pick up a little bit of flow, but some deeper tone and louder. I have NPP with the fuse #41 pulled, and it sounds REALLY good!
No dyno time, but my ricer math says this package is probably 40 hp and 35 tq
Old Mar 16, 2015 | 09:54 AM
06MonteSS's Avatar
06MonteSS
Supporting Vendor
Nice!! :-)
Enjoy man!
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS LS3, short-throw shifter, NPP perf. exhaust, BMR strut-tower brace, Cold Air Inductions cold air intake, catch-can, ported/polished TB, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Mar 16, 2015 | 02:57 PM
Kracka's Avatar
Kracka
Throttle progression doesn't matter once the pedal is mashed, I personally kept mine at 0% increase
X-pipe info: https://www.corvetteforum.com/forums...-vs-corsa.html
Old Mar 17, 2015 | 01:01 AM
M3GUY01's Avatar
M3GUY01
OP, since you dont have access to a dyno, you should try the 40-100 mph test timer in performance mode. As a baseline you will see most stock c7s run it in about 6 seconds flat.
That way you can see if the mods improved your accerlation over stock.
Would be very interested to see your results/time!
Old Mar 17, 2015 | 09:38 AM
jyounger74's Avatar
jyounger74
Your in good hands with Diablew he has been tuning all my GM CARS FOR MANY YEARS
Old Mar 17, 2015 | 10:02 AM
crazybiker51's Avatar
crazybiker51
It's a shame lew doesn't do FI, want a tune done for headers, would be nice to update it in a few months when FI gets bolted in, seems like not too many do tunes thru Diablo
Old Mar 17, 2015 | 01:27 PM
dovervold's Avatar
dovervold
Great idea, that should tell a lot. Weather has dropped cold again in Minnesota so might be a few days before I can get her out on the road again... Will report back when I get this done...
Old Mar 17, 2015 | 02:06 PM
Russodiablosport's Avatar
Russodiablosport
Supporting Vendor
ECS, and Florida Speed and Power can definitely get you you taken care of for forced induction, both of them use our software.
Old Mar 17, 2015 | 02:09 PM
crazybiker51
Thanks for the reply Russ, perfect, was going to go with ecs for the supercharger and just saw that they use efi live, will be contacting them
Old Mar 17, 2015 | 02:10 PM
aFe POWER's Avatar
0aFe POWER
Former Vendor
We are very happy you like the combo. Thank you for using aFe as your intake choice!
To AFE + TB + Corsa + DiabLew =
