Will a 305/35/20 drag radial fit on stock Z51 rim
Yes it's the NT05r and the fronts are the stock tires. No issues with tpms at all. Mounted them up and drove on them for the weekend without any issues other then rubbing like I mentioned earlier. But that's only because I lowered my car a lot. Raised it up a bit and it was perfect.
I have 20inch cray brickyards on the rear and tried mounting 305/35r20 mt e/t streets and they rubbed like crazy even at stock height. Wayyyyy too tall, sold them and got 315/30r20 r888s in back and they only very slightly rub when cornering real hard. They stick really well on the street. Im making 650/650.
C7 2015 stingray tire problem
I'm having trouble with my tires as well i have 19s in the front and 20s 285/30/20 in the rear all stock, i first wanted to put some mickey thompsons 305/35/30 and it was hitting and scratching so i took them off
what drag radials can i put in the rear without me having to replace the rim or mess with the back? I'm looking for something that slips right in to my 20 rims
help please
her are some pics of when i put the mickey thompsons 305/35/30
and my michelin stocks 285/30/20
mickey thompson 306/35/30 did not work out on my car at hitting the back and when i turn as well
help please
I have asked this question via a thread as well, but did not receive a definite answer. There is ONE member here (Theta) that has the Toyo R888 315/30/20 on the rear with stock Z51 rims with no issue. However, I have not heard of anyone else. A few members run the Toyo R888 285/35/20 in the rear Z51 stock rim with no issues as well.
help please
help please
No I did not those Mickey Thompson 305/35/20 when I drove off started scratching my rear fender and in bumps it would scratch as well also when I turn so I took them of my car right away...and threw the stocks back on (285/30/20)
That sucks I was thinking bout ordering those now I have to go with the Toyo R888 but I don't no if they hook good on the 1/4
I went the same way installed the MT then they got ruined
the best match for us is the R888 or R888R and to be honest they're not bad at all.
The fit perfectly to my Z51.
Big transformation from the stock tires
John Micheal Henry (05-17-2018)
#33
I had 285/35/20 RS-3s on my car and it rubbed on any dip with rear full lowered. Rubbed at the track only at 1/2 height. Does not rub at all at full lift. It was rubbing at the back and front of the wheel house. Definitely too tall. I don't know how you guys car run 315/35, must have rubbed at any slight curve or dip. Sure it wasn't 315/30?
#34
I'm Batman..
Pro Mechanic
#35
Received 1,762 Likes
100% correct on this,,,, all tires manf are not the same even if the same size is on the side wall.
#36
This: Bridgestone RE-71r in 295/30/20. They hook really well and fit perfectly.
#38
