Flex Fuel Kit
Old Apr 8, 2015 | 01:37 PM
Seannyc's Avatar
Seannyc
Default Flex Fuel Kit
What Place Sells the flex fuel Kit and is there a kit that can use any gas from 87 to 93 and higher not sure how they work but what's the best kit out
Old Apr 8, 2015 | 01:45 PM
Higgs Boson's Avatar
Higgs Boson
ben@weaponx
use 93 or E85 with the kit. never use less than 91/93.
NEVER!!!!
Old Apr 8, 2015 | 01:47 PM
Seannyc's Avatar
Seannyc
Originally Posted by Higgs Boson
ben@weaponx
NEVER!!!!
Thanks What does the flex fuel exactly do how does it gain HP IM lookin to buy it I don't no were can I get one and how does it work
Old Apr 8, 2015 | 02:08 PM
Higgs Boson
weaponx.com
the flex fuel sensor and appropriate tune will allow the engine computer to measure alcohol content in the fuel and make necessary changes to the fuel mixture and spark timing in order to take advantage of running E85 as your car can make more power properly using E85. If there is no E85 fuel stations in your area then this would be a pointless modification.
Old Apr 8, 2015 | 02:13 PM
Seannyc's Avatar
Seannyc
weaponx.com
Yah my area has it I live in New York I no a few stations what's the price to install it
Old Apr 8, 2015 | 02:44 PM
Higgs Boson
most guys are doing it themselves. i'm cheap so i just built a full tune for E85 but I have to reflash the computer for 93. the kit will make it so the car adjusts automatically.
I can't see a time when I will run anything other than E85, I don't road trip the car or anything so for me it's moot.
Old Apr 8, 2015 | 03:18 PM
Seannyc's Avatar
Seannyc
Do u have a place in New York in I could get this done thanks for the information
Old Apr 8, 2015 | 03:20 PM
Higgs Boson
no sorry, i am in texas. hopefully someone else will chime in for you.
Old Apr 10, 2015 | 03:58 PM
LT1_E85_Corvette's Avatar
LT1_E85_Corvette
I can back what Higgs is sharing. Great info
Old Apr 10, 2015 | 06:04 PM
RideZX6R's Avatar
RideZX6R
Fasterproms also sells a kit jfyi
Old Apr 10, 2015 | 07:36 PM
CDH76's Avatar
CDH76
Higgs I'm cheap too. What are you using to tune with? Is there a DIY posted up on how to do this kit? Something I would like to do as well.
I'm in Texas as well, maybe I send my car to your "tune shop"
Old Apr 10, 2015 | 07:39 PM
Hawk03's Avatar
Hawk03
I had not even thought of that, I already have hptuners.
Old Apr 10, 2015 | 07:41 PM
CDH76's Avatar
CDH76
You have one of these? Scanner or Suite?
http://www.hptuners.com/products/
Old Apr 10, 2015 | 08:22 PM
Higgs Boson
Sure, I can definitely tune it for you.
I use HP Tuners to tune GM vehicles. There is a thread or two about installing the Flex Fuel sensor but nothing I have seen on just changing the fuel and making a new tune. It's not too hard if you know what to do. I can do it for you or walk you through it, either way. HP Tuners has a learning curve though, I will warn you.
Old Apr 10, 2015 | 09:46 PM
Hawk03's Avatar
Hawk03
Suite, Pro version.
Old Apr 11, 2015 | 12:40 AM
CDH76's Avatar
CDH76
Really? That would be great! I'll take a look at the kit on weaponx site and if it sounds like something I will do I will be touch. Thanks so much for the offer! If we did this maybe I could learn a few things from you and buy my own tuner after for future adjustments.
How is this type of tune compared to what a shop would do? Same stuff?
Hawk03, thanks for confirmation sir! Is there a reason you went with pro over the standard?
Old Apr 11, 2015 | 08:01 AM
Higgs Boson
yes, it's a custom tune made for your car.
go with pro so you can easily hook up a wideband oxygen sensor.
To Flex Fuel Kit
Old Apr 11, 2015 | 10:42 AM
Hawk03's Avatar
Hawk03
As Higgs Boson mentioned, the pro lets you use a wideband.
Higgs Boson- PM sent.
Old Apr 11, 2015 | 01:27 PM
CDH76's Avatar
CDH76
Thanks guys! Great info
Old Apr 12, 2015 | 02:05 PM
CDH76's Avatar
CDH76
Pretty sure I just found this flex fuel sensor for $45-$55 bucks. Is there something I'm missing on why weaponX wants $600?
I'm guessing I have the wrong part number but it looks exactly the same so I'm curious!
EDIT: Nevermind I've been reading some other topics I see that it's a kit with more then the sensor.
