C5 axles on a C7 anyone?
Old Oct 5, 2017 | 03:06 PM
walhan_qtr's Avatar
walhan_qtr
C7z is same as C7 axles. Never had to change the axle ever since I did the upgrade (running pass axle on drive side). Multiple 1.4 60ft (auto) but honestly didnt beat on it alot to find out if they will handle real abuse. Car ran multip mid 9sec passes on DRs.
Old Oct 5, 2017 | 04:07 PM
JHEBERT's Avatar
JHEBERT
Ohh crap... here we go Dave, more money for shafts
Mother b!7ch!
I really thought we could do without upgrading
Old Oct 6, 2017 | 10:52 AM
MIGHTYM0USE's Avatar
MIGHTYM0USE
Mother b!7ch!
i don't know what the limit is, but i personally don't want to be the one to find it either.
Old Oct 6, 2017 | 11:02 AM
walhan_qtr's Avatar
walhan_qtr
Yours an A8 so I wouldnt worry much. I believe Sam ran multiple low 1.3 60ft times. He did break a couple, but he did also beat on it. You will be fine in the 1.4 I would think, the 1.3s you might start breaking them. Just buy dss if you are worried and planning to beat on the car at the drag strip. If only doing slme testing and couple of passes here and there I would just swap them when they brake.
Old Oct 6, 2017 | 11:52 AM
MIGHTYM0USE
I am already 1.3x's and the car is not lightened, also do not usually trailer.
Old Oct 6, 2017 | 12:44 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
At a certain point you have to start worrying about blowing out the rear end after moving to beefier axles. Personally, i'd consider doing that first before the axles as having stronger axles and a weak pinion setup is a recipe for bad chit to happen..
Old Oct 6, 2017 | 01:16 PM
robert miller's Avatar
robert miller
I just now doing the WAVETRAC from RPM with a diff gear set up. I am calling it a day with this on the car no were at the power level that you guys are at now. But these rear ends are crap with 600 plus rwhp & drop clutch the car. Robert
Old Oct 17, 2017 | 11:29 AM
walhan_qtr's Avatar
walhan_qtr
I dont know why thy say to drop the clutch with those c7s. I believe with the right clutch, it should handle a slip and go. I broke 2 rear ends by dropping the clutch. If you slip it it should handle just fine.
As far as do the rear end before the axle, notmally you fix weakest point and move up. Sure if you can do both at the same time is better, but why chamge the rear end if the axle cant handle breaking it!n
Old Oct 18, 2017 | 05:33 PM
robert miller
Default ttt
This came up a few years ago but one guy that had a c5 did look at doing it & posted back up in here on that post then that they would not fit. But I am not sure from me trying it myself.
OK the driveshift shop says will not fit.
Old Jun 10, 2018 | 04:10 PM
KENS80V's Avatar
KENS80V
The axle outboard stubshaft on a C5 is 30 spline. The stubshaft on a C7 is 33 spline.
Old Oct 3, 2018 | 11:10 PM
SuperdadZ06's Avatar
SuperdadZ06
interested in the Loyds mats and the waterfall............
