Need Definitive Y/N - Tire diameter diff F/R - Computer Issues?
Old Apr 19, 2015 | 05:55 PM
NTMD8R's Avatar
NTMD8R
Default Need Definitive Y/N - Tire diameter diff F/R - Computer Issues?
We know the front and rear tires have a diameter difference.
I have "heard" that the difference in diameter is monitored (via revolutions) by the computer,
AND,
If that difference is NOT within certain minimum/maximum,
it will put the vehicle into "limp" mode.
But I have never actually heard of any person who has experienced this.
I would like a definitive Yes or No that this does happen.
And, if so, what are those minimum and maximum values.
Old Apr 20, 2015 | 09:49 PM
Dangerous Don's Avatar
Dangerous Don
I recently put 305/35/20's on the rear of my car and yes, the car goes into a sort of "limp" mode, but it's not what you think. The car still has all of the engine power, although you lose all of you traction and stability control, along with the steering becoming extremely stiff as if not having power steering. As far as the percentage difference you're looking for I have no idea, but I also know that if you change the tire size and this happens that you can bring your vehicle to the dealer and they will recalibrate it for the new tire size. Hope this helps.
PS, I do not recommend the use of 305/35/20 tires due to rubbing issues.
Old Apr 20, 2015 | 09:52 PM
EcoBrick Bob's Avatar
EcoBrick Bob
Dazed Confused & Verklemp
The key is to keep the ratio of tire size between fronts and rears close to the same. So if you raise the diameter of the rears by .5 you need to raise the fronts by close to the same... maybe .45.. all relative to the original diameter comparison.
Old May 7, 2015 | 01:33 PM
NTMD8R's Avatar
NTMD8R
EcoBrick Bob,
Sorry... not true.
I have installed (for the time being) 265/35/19 front and 285/35/20 rears,
for a diameter difference of 1.4"
No discernible difference in any performance.
Old May 8, 2015 | 08:21 AM
6Speeder's Avatar
6Speeder
People have said the same thing about the C5 and the C6, that you have to keep the rears taller than the fronts. I found that not to be the case. I ran tires that were the same diameter, front and rear, for years with no computer glitches. I suspect the C7 will prove to be the same.
Old May 8, 2015 | 10:38 AM
jessrayo's Avatar
jessrayo
I don't have actual experience with the C7 yet, still on the stock tires.
But I have a 2013 ZL1 Camaro that that has raced on 6 different tire sizes including drag racing with various drag radials and not matching fronts. My experience with the Camaro comes to this. You can vary stock ratio about 1 inch without throwing the stabilitrac code. Since the C7 has a 0.7 inch difference from front to rear that would come to roughly you could run a front about 1.7 inches shorter to about 0.3 inches taller than the rear without electronic issues. Haven't actually tested it on the stingray but what Dangerous Don describes is exactly the response I get in the Camaro and usually drag race with no stability and a stiff power steering feel because I run taller drag radials for better times on my Camaro. I'm guessing he is running the 305 Pirelli p zero which would be about 2.6 taller than the front.
Old May 9, 2015 | 02:50 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
You shouldn't notice any codes ABS or otherwise when altering the difference between the stock difference in heights between the front and rear---HOWEVER your ABS system will NOT be at 100% efficiency--- That is a hard thing to prove as the only time you will notice that the ABS is NOT working correctly is when you need it the most---on a panic hi-speed stop !!!! It's your life do what you like---But I would never gamble changing the stock height split regardless how much the car looks better with larger wheels--The "split" difference is built into the ABS controller and cannot be changed--
Old May 9, 2015 | 08:00 AM
6Speeder's Avatar
6Speeder
How do you know the ABS is set for the split? I believe the ABS operates independently, on each wheel, keeping each wheel from locking, again, independently.
Now the TCS is another matter. I know if you install too tall rear tires the TCS can intervene and ADD some throttle when it thinks the rears are slipping from throttle shut down.
Old May 10, 2015 | 04:04 PM
jessrayo's Avatar
jessrayo
I suspect the vette is the same as the Camaro, and once you roll about 50 feet with significantly different sized tires front to rear the information center on your dash flashes a series of messages. stabilitrac error...... stabilitrac off.......power steering error.... the stabilty icons on the dash remain lighted and you have no stability or traction control. The abs seems to continue to work fine, I can still mash the brakes and make the first turnout with no drama after hitting 130+ in the 1/4 mile. Does not affect the engine at all, it is all a matter if you need stability and traction control. Every time you restart the car it resets and you go through the warnings again until you put the correct ratio tires back on the car.
Old May 11, 2015 | 01:57 AM
tblu92's Avatar
tblu92
The ABS and TC both use wheel speed sensors for input to control various functions--- The ABS system uses the wheel speed sensors from keeping the tires from skidding on a hard stop--The TC uses the wheel speed sensors from keeping the tires from spinning on a hard launch---So both are affected by altering the stock split of 1" from rear heights to front--- as I said you can do whatever you like--But it has been my experience that the TC issue is no bid deal--however the ABS issue may save your life---
Old May 11, 2015 | 08:32 AM
6Speeder's Avatar
6Speeder
I have run different sized tires on my Vettes from 2000 on. Some were the same diameter front and rear, some with the rears much bigger than the fronts. NEVER had ABS issues. It's not a problem.
Old May 11, 2015 | 10:20 AM
jessrayo's Avatar
jessrayo
Running tires of significant size differences from stock will not affect Engine performance or ABS. They both work fine. After you roll about 50 feet it gives a stabilitrac warning and then says stbilitrac disabled, then you get a power steering warning. The power steering system continues to function but at reduced boost.
Old May 11, 2015 | 01:52 PM
NTMD8R's Avatar
NTMD8R
And this is why I'd like a DEFINITIVE Answer from someone at GM.
We are getting all sorts of answers here.... many in conflict with one another,
based on experience and/or heresay.
To Need Definitive Y/N - Tire diameter diff F/R - Computer Issues?
