How-To: Remove/Replace Front Brake Rotors
Old Apr 29, 2015 | 01:56 PM
Theta's Avatar
Theta
St. Jude Donor '14-'15
Default How-To: Remove/Replace Front Brake Rotors
The following How-To covers the explanation of how to Remove/Replace the Front Brake Rotors and includes specifications, schematics, etc.
These How-To guides are neither endorsed by or property of Corvette Forum or myself in any way/shape/form. All liability stemming from any actions taken in relation to these guides is solely placed upon the user.
We hope you will find these guides useful.
Old Apr 29, 2015 | 01:57 PM
Theta's Avatar
Theta
Theta's Avatar
Theta
Old May 10, 2015 | 10:20 AM
Jedi-Jurist's Avatar
Jedi-Jurist
St. Jude Donor '15
Any advice on how to remove the rotor bolt? It won't come loose and I don't want to strip it.
Old May 10, 2015 | 10:43 PM
Jedi-Jurist
St. Jude Donor '15
So, I stripped it. Anyone know what the part number is for the rotor bolt? While I'm at it, what are the part numbers for the caliper bolts? They're a PITA to clean, I would rather have just used new ones. Thanks!
Old May 10, 2015 | 10:50 PM
Theta's Avatar
Theta
It stripped coming out? Jeez... They must have screwed up the torque when installing it, since it's less than 9 ft/lb.
I'll get you the numbers.
Old May 10, 2015 | 11:02 PM
Jedi-Jurist
St. Jude Donor '15
Instructions say 106 lb feet, is that not right?
I think the bolt part number might be 11570339.
Having trouble finding the caliper bolt numbers.
Old May 10, 2015 | 11:03 PM
Theta's Avatar
Theta
106 INCH pound.
Brake rotor bolt PN is, as you have, 11570339.
Front Brake Caliper Bolts w/ Adhesive PN: 11611085
Old May 10, 2015 | 11:32 PM
Jedi-Jurist
St. Jude Donor '15
Doh! Then they really were overtorqued
Old May 12, 2015 | 04:56 PM
Jedi-Jurist
St. Jude Donor '15
I would recommend using one of these on the rotor screws. Even though mine were only about 3 months old (in driving months), they were a PITA to turn. This would have helped tremendously.
Old May 12, 2015 | 09:46 PM
baron95's Avatar
baron95
What size socket is needed for caliper bolts?
And any instructions on how to change the rears? Do I need to do anything related to the parking brake or is it pretty much like the fronts?
And why such huge torque numbers for the caliper bolts? I have stripped the aluminum while tightening caliper bolts on another car so I am paranoid about over tightening and stripping.
Thank you - first time Corvette owner here - I have 2015 Z51.
Old May 15, 2015 | 01:08 AM
Theta's Avatar
Theta
Rear instructions are located here: https://www.corvetteforum.com/forums...ke-rotors.html
I believe the socket is a 13mm, but this is only a 'guess' from having worked with these more than a year ago.
As for the torque value, I can't speak for the engineers who deemed this high number necessary. We do have another member's post that confirmed the torque required to remove the the factory-installed bolt, and the absence of damage from re-torquing to this (seemingly-high) torque spec. It is the correct number per GM, though.
Old May 15, 2015 | 09:39 AM
Greg00Coupe's Avatar
Greg00Coupe
Is 106 lb per INCH yes INCH.........not that much torque? Posted above in one response said 106 lbs........... big difference when you miss the inch me thinks.
That impact drivers is sweet. If anyone ever changes brakes on foreign cars....... you have been there done that. Its a miracle tool.
But before you invest in one......try to put a little pressure on the screw clockwise........yes.... tighten first, just smige to try to move the screw then try to back it out. And precede this with a little penetrating oil.
Old May 15, 2015 | 10:07 PM
baron95's Avatar
baron95
Are the rear caliper bolts the same as the fronts? All parts ordering sites on line do not list the caliper bolts. I'd rather replace them than having to clean them.
Thanks.
P.S. I did find the rear replacement guide - thanks.
Old May 15, 2015 | 11:32 PM
Theta's Avatar
Theta
Greg, there are a few posters talking about different things here. The rotor screws/bolts only require 106 in lb, while the caliper bolts require 162 ft lb - certainly a large difference there.
But it does appear that some poor soul read the 106 in lb as ft lb.
Old Jun 8, 2015 | 11:27 AM
baron95's Avatar
baron95
Is this really right? Tighten the caliper bolts (which go in an aluminum bracket) to 162 lb ft?!?!
That is 60% more torque than wheel lug nuts.
I'm not sure I have a torque wrench that goes to 162 lb ft that will fit in that space.
Old Mar 29, 2016 | 09:09 PM
Jedi-Jurist
St. Jude Donor '15
I created a how-to video on changing the front rotors:
To How-To: Remove/Replace Front Brake Rotors
Old Mar 30, 2016 | 02:52 AM
CDH76's Avatar
CDH76
Nice video. Which dba rotors are those?
Old Mar 30, 2016 | 10:24 AM
Jedi-Jurist
St. Jude Donor '15
Thank you. Those are the DBA T3 rotors that I got from KNS Brakes (forum sponsor: https://www.corvetteforum.com/forums...-and-base.html). Been very happy with them thus far.
Old Apr 1, 2018 | 10:26 PM
cubarican84's Avatar
cubarican84
Default Sheared Rotor Torx Screw
Set torque wrench to 106 in lb not foot pound. Screw sheared off. Do i even need to replace these torx screws? Or is this just an assembly line screw to hold rotor in place? I honestly dont even know what went wrong ive used torque wrenchs before. For some reason the wrench must have malfunctioned
