P0128 Diagnostic Code
Old May 28, 2015 | 12:36 PM
Mike@DiabloSport's Avatar
Mike@DiabloSport
Supporting Vendor
This is a rather common code on Chrysler HEMIs when using a cooler t-stat, the Chrysler PCMs have a high/low threshold for running the P0128 test and we just raise that up to get rid of it rather than disable the code.
Hope that helps.
Old May 28, 2015 | 03:48 PM
Higgs Boson's Avatar
Higgs Boson
My C7 runs about 170-175 cruising down the highway with a 160 stat in pretty much any temp below 90 degrees. I don't think I have had a warmer day yet. No codes, but I also changed the thermostat table from 194 to 160.
Old May 28, 2015 | 09:35 PM
EcoBrick Bob's Avatar
EcoBrick Bob
Dazed Confused & Verklemp
I pulled my 160 Lingenfelder T-stat today when I was installing my new Halltech CAI. The seal was cut thru in one place and had a second small cut. When I went to install the new 170 deg one from them that I purchased, I noticed that the bottom of the spring where it is cut off was pushing into the rubber seal. So, I pulled the spring out and filed off the end so it was curved and smooth. Put everything together and it seemed to make a big difference in the rubber seal deflection at that point.
Several posts on this thread refer to cut/damaged seals. The stock T-stat has a built in seal on the pin side that doesn't touch the edge.
I took several pix of the seal and have forwarded them via e-mail to Lingenfelder. I did not test the T-stat in boiling water. Hopefully they will get back to me with either replacement seals, or a new T-stat.
My goal was to see 175-185 cruising temps, and I bought the 160 based on my experiences with aftermarket 160-170 deg T-stats in my other 3 vehicles. Mine in the Vette were always below that, in the 155-165 range for the most part.
Didn't have the DashHawk with me today when I tested the Halltech CAI, so can only report temps from the instrument panel gauge in the range of 175-190, if it is accurate. Oil temp was around 200. Forgot about checking in performance data center.
Halltech certainly sounds good!!! No whistle with it in combination with my Faster Proms/Formato Ported Intake Manifold. Certainly feels faster than my high 11 sec. Modded G8 GT, but maybe I'm just dreaming. No pipes or tune... yet!
Old Jun 6, 2015 | 02:13 AM
ect's Avatar
ect
I just installed my 3rd. 2nd one had split. My chamfering of the c,bore did not work! It seems the spring can not stay centered on the base plate pushing the o-ring off the edge of the base plate cutting (gumming) it in two. The seal feature should be exactly like the stock one.
Old Jun 6, 2015 | 11:27 AM
Higgs Boson
This may be why the first ones to come out included the housing as well, which is what I have installed without an issue (at least not yet).
Old Jun 11, 2015 | 02:34 AM
ect's Avatar
ect
Higgs did you get a housing for your c7 t-stat? thanks eric
hi
Old Jun 11, 2015 | 07:22 AM
Higgs Boson
yes i bought the whole housing/stat assembly before the individual thermostat was available.
Old Jun 11, 2015 | 09:42 AM
ect's Avatar
ect
Higgs may i ask from whom you bought it? thank again eric
Old Jun 11, 2015 | 09:57 AM
Higgs Boson
https://www.corvetteforum.com/forums...t-housing.html
https://www.corvetteforum.com/forums...-in-stock.html
Looks like I posted in the second thread about waiting for a cheaper one but I guess I must have caved and spent 300 bucks. Couldn't wait.
