M7 throttle on dragstrip launch going dead
Old May 27, 2015 | 03:52 PM
Higgs Boson's Avatar
Higgs Boson
have you been back to the track after making the changes we talked about?
Old May 27, 2015 | 04:38 PM
MIGHTYM0USE's Avatar
MIGHTYM0USE
true
i feel like i am triggering reduced power mode, just dont now what criteria to look at at the 0mph or vs tps, and if it is driver demand related or maximum torque related.
going to try to capture it on a scan next few days fingers crossed.
Old May 27, 2015 | 04:39 PM
MIGHTYM0USE
yes what you saw was prior to the re-tune and of course it picked up power and drives around better but same issue on launch.
Old May 27, 2015 | 04:53 PM
Higgs Boson
here's a dumb question and one that might have been asked.....you are turning off traction control and stability control?
Old May 27, 2015 | 07:07 PM
10mm_'s Avatar
10mm_
St. Jude Donor '15
Originally Posted by MIGHTYM0USE
true
I would think it's maximum tq related, I mean WOT is WOT so driver input should be the same on your car as mine, the difference is the fuel delivery and spark and the ECU is probably calculating that the torque produced exceeds the targeted value (whatever the max is at WOT) and closing the throttle body to try to get back down to that max torque value.
I'm not a tuner I don't know spit so don't listen to me
Old May 27, 2015 | 11:02 PM
Higgs Boson
It's not Max Torque or Driver Demand related, I have seen his tune.
One would almost just have to be there or drive the car or log the appropriate things to duplicate the symptom.
Old May 28, 2015 | 12:06 AM
3 Z06ZR1's Avatar
3 Z06ZR1
well i mean its got longtubes and an a&a kit so it was 'tuned' for that twice before i owned the car and then i had my guy go in and do damage control, but we havent figured this one out yet.
Hope you get it figured out. You need to seek a known good tuner
on C7's
who can dyno tune the car and get it right. It did this same symptom's. On the street it would fall on it's face when pressed for power then pick back up.
Right after I had the kit put on then. Straightened out on it own
after a week. Just got more and more better until I had it full rpm back then it never did it again. But esp since you have added long tubes and a meth kit you should get it to a known pro shop there are many.
Best of luck!
Old May 30, 2015 | 10:21 AM
itsonlyairandfuel's Avatar
itsonlyairandfuel
Originally Posted by Frans96ss
Its in the tune... I promise you.... This is my car. Went a 1.51 60 multiple times with no problems.
C7 Corvette Goes 10s and PULLS WHEELS - YouTube
Great launch, what size and brand of tire are you using? Thanks Ron B.
Old Jun 12, 2015 | 11:38 AM
MIGHTYM0USE
track tonight with only changes being powerhop and oil starvation disabled.
trying to do myself/everyone a favor and identify 'who dun it' exactly.
Old Jun 12, 2015 | 03:32 PM
Frans96ss's Avatar
Frans96ss
St. Jude Donor '09
In that video it was a BFG drag radial. Hoosiers will work way better though. Just used them bc they were on the rims already.
Old Jun 12, 2015 | 04:36 PM
Complete Street's Avatar
Complete Street
Supporting Vendor
Like everyone else said, it's the tune. I will tell you there are certain settings on the c6 that are normally changed that when done on the c7 do this exact throttle killing stuff. Took me a bit of testing on my own c7 to figure out the exact settings. So, against the wife's wishes, I'm glad I bought my c7 to tinker lol.
Good luck.
Old Jun 12, 2015 | 05:21 PM
Higgs Boson
mighty mouse, if you only changed those two things, i think there will be one more table you need to change that i mentioned to you on email. ;-)
if you can change it at the track you are welcome to call me.
Old Jun 15, 2015 | 03:51 PM
  #33
MIGHTYM0USE
despite the muggy conditions i was able to get a new best ET and 60' after disabling 'powerhop' and 'oil starve' under engine / tq management / general. disable at your own risk. I have a feeling it was just the powerhop one but whatever at this point, someone else can feel free to isolate further.
thanks goes to Higgs Boson for the pointers.
if the problem rears its head again on future track visit ill be sure to update.
Old Jun 15, 2015 | 03:57 PM
  #34
10mm_'s Avatar
10mm_
St. Jude Donor '15
That's good you got it fixed.
What you run?
Old Jun 15, 2015 | 04:18 PM
  #35
MIGHTYM0USE
that was a 11.23 on a 1.71 at 124.3. its been 127 in better air. was pretty brutal fri night was 93* +2000DA on this run which is about as bad as the air can get in richmond va lol.
Old Jun 15, 2015 | 04:40 PM
  #36
10mm_'s Avatar
10mm_
St. Jude Donor '15
Yeah that's pretty hot lol. Were you at Richmond dragway or dinwiddie
Old Jun 15, 2015 | 04:56 PM
  #37
Higgs Boson
you'll go 10s in good air. what are your mods again?
To M7 throttle on dragstrip launch going dead
Old Jun 17, 2015 | 12:48 PM
  #38
MIGHTYM0USE
richmond, mods are a&a base kit, single meth, pfadt headers, 160 stat, nitto dr's. it made 583rw in better weather when tuning
Old Jun 17, 2015 | 01:20 PM
  #39
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Were you tuning for power with the Meth or just using it for safety?
Old Jun 17, 2015 | 01:55 PM
  #40
MIGHTYM0USE
safety i guess considering were only at 13* adv. at 8# boost.
