0-60 timer
Old May 14, 2015 | 08:10 PM
knote's Avatar
knote
Default 0-60 timer
My best time so far. Tried it with track mode and traction control off. 7sp manual with a&a kit on factory tires. Wheel spin is hard to avoid
Old May 14, 2015 | 10:19 PM
dovervold's Avatar
dovervold
Yikes Stock car is in the same range. Traction is just tough out of the hole. Now here is a good test: 40-100 MPH. Lots of us getting 6 seconds or less. E85 guys running low 5's.
BTW, I ran an A & A on my 2007 and loved it!!! No traction from scratch but once it hooked holy hannah
Old May 14, 2015 | 10:38 PM
knote's Avatar
knote
I know stock ones run that but this is a real challenge with the stock rubber. I assume the manual guys leave in 2nd gear for the 40-100 test? I will try this next!
Old May 15, 2015 | 12:21 AM
T/A KID's Avatar
T/A KID
Not to be rude....but if I had a blower on my car I would want that less than 3 seconds
Old May 15, 2015 | 12:38 AM
ilivas's Avatar
ilivas
It's tough to do much better than that on stock tires.
Old May 15, 2015 | 01:15 AM
Theta's Avatar
Theta
St. Jude Donor '14-'15
That's a lot harder than it sounds, especially with the M7 and a crapload of power, even on drag radials - trust me.
Old May 15, 2015 | 09:10 AM
DAFFYDRUNK's Avatar
DAFFYDRUNK
My bone stock 15 convertible is basically traction limited in 1st already so the limitation to 0-60 is not power, it's tires.
Old May 15, 2015 | 09:48 AM
robertf97's Avatar
robertf97
Best I could get with stock tires was 4.2 s in three tries.
With some other tires I was able to get 3.6 s on the third attempt.
Old May 15, 2015 | 07:28 PM
Mike Campbell's Avatar
Mike Campbell
I don't know how you did it but I couldn't get that screen or the 0-60 timer to start.
Old May 15, 2015 | 09:58 PM
knote's Avatar
knote
You will find it under the performance screen..not info, nav, audio etc. Once you find the timer you can select a start speed and an ending speed. The reset button will be your friend!
Old May 15, 2015 | 11:48 PM
Theta's Avatar
Theta
God, if that isn't the truth.. I always edge right over the 45 by mistake and have to quickly reset it.
Old May 16, 2015 | 01:09 AM
OLD_GOAT's Avatar
OLD_GOAT
Dumb question for the night.
Is the timing on the PDR connected to the timer on the instruments?
I got a time of 3.60 (0-60) on the PDR on a 0-75 mph sprint, would this be the same as the other timer? If it's not the same, would one be more accurate than the other?
Old May 16, 2015 | 09:45 AM
Mike Campbell
knote:You will find it under the performance screen..not info, nav, audio etc. Once you find the timer you can select a start speed and an ending speed. The reset button will be your friend!
Thanks, I'll try it out.
To 0-60 timer
