Disabling X-pipe cats
Old 05-28-2015, 08:20 AM
davekp78
davekp78's Avatar
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Default Disabling X-pipe cats
Has anyone disabled their X-pipe cats? How? It looks like you can get to them easily- are they ceramic type that can just be busted up?
Old 05-28-2015, 11:10 AM
Matt26
Matt26's Avatar
Get a Borla/Corsa X-Pipe that does not have cats, bolts right up.
They are like $400
The stock ones are a honeycomb design if I remember correctly, not sure of the material.
Old 05-28-2015, 11:49 AM
PJake
Support Corvetteforum!
PJake's Avatar
The Corsa one is less than $400 and it works really good on a C6. Check youtube the C7 one looks NICE...
Old 05-28-2015, 08:42 PM
davekp78
davekp78's Avatar
Well the C-7 Corsa is $560 and the Borla is $440. I'd rather not spend that if I can just bust up internals of the OEM cats.
Actually, the OEM looks like it flows pretty good- not like the OEM C-6.
Old 05-29-2015, 10:34 AM
TXArtic
TXArtic's Avatar
The OEM cats are a metal material, NOT ceramic...and...they are a pain. Still working on gutting them.
Old 05-29-2015, 11:43 AM
bob guzzy
bob guzzy's Avatar
Why bust them up when you can sell them and recoup some of the money you laid out for the borla.
Old 05-29-2015, 12:03 PM
davekp78
davekp78's Avatar
I doubt the OEM are worth very much.
Old 05-29-2015, 12:04 PM
davekp78
davekp78's Avatar
Good answer.
Thanks!
Old 05-29-2015, 08:57 PM
PJake
PJake's Avatar
WOW....pricey. I would hope that's a 3" pipe for that price.
Old 05-31-2015, 10:04 AM
mkr1966
mkr1966's Avatar
Corsa is 3".
Old 06-03-2015, 08:28 AM
Kracka
Kracka's Avatar
Received 5,716 Likes on 2,921 Posts
C7 X-pipe comparisons: https://www.corvetteforum.com/forums...-vs-corsa.html
Old 06-27-2015, 09:42 PM
slesher
slesher's Avatar
You could also add boost and melt them like I did
Old 06-28-2015, 07:06 AM
marcouvo
marcouvo's Avatar
How about cutting the secondary cats off of the stock intermediate pipe, cut the flanges off the stock cats, and weld the flanges onto straight pieces of pipe, fitting up to the exhaust manifolds?
That should be a lot less than $440, though kind of a hack job.
Old 06-28-2015, 08:08 AM
davekp78
davekp78's Avatar
I managed to remove the converter innards in the X-pipe cats. A lot of work, with a lot of sweat and swearing. Made a difference in the sound but not as much as I had hoped.
Old 06-29-2015, 05:22 PM
Theta
Theta's Avatar
St. Jude Donor '14-'15
Sorry to hear that - the negative about having the remaining cat bodies there are that they are acting as a very simplistic resonator (more akin to an attenuator) and slightly altering the sound you'd get with an aftermarket X.
Though, overall, there's not a ton of sound to be gained there (and no performance), so you're probably still ahead of the game, at least dollar-wise.
Old 06-29-2015, 05:33 PM
slesher
slesher's Avatar
Was thinking of this too but there is an advantage to keeping the hollowed stock secondary cats.
If you live in an area that does a visual cat inspection or even drive through one and get caught you'll wind up with a horrific fine.
Don't know from personal experience but have heard stories.
Old 06-29-2015, 05:37 PM
C7/Z06 Man
C7/Z06 Man's Avatar
Now that you have removed the innards what would you suggest to others who may be thinking about this that would make the job better, quicker and easier?
To Disabling X-pipe cats
Old 06-29-2015, 05:39 PM
Theta
Theta's Avatar
Remember, secondary cats are exempt from visual inspection (even in California) as they are beyond the emissions control system. I had a pretty good post about that but can't find it at the moment.
Old 06-29-2015, 08:42 PM
Jack Be Quick Racing
Jack Be Quick Racing's Avatar
Location: Detroit area and Nashville area What day is it? Between MI & TN
Stock:
Corsa double helix:
Old 06-30-2015, 07:03 AM
slesher
slesher's Avatar
Your right! I'm wrong. Got the primary and secondaries mixed up. Thanks
Quick Reply: Disabling X-pipe cats
