Exhaust question
Old Jun 9, 2015 | 09:33 AM
eLiT3_Z51's Avatar
eLiT3_Z51
Cruising
Default Exhaust question
This may be a dumb question. But, I would appreciate some input. I want to pull of the factory mufflers/tips to be powder coated and was wondering if it would cause any issues to drive for a day with them off?
Will that throw any sensors because of back pressure? Cause issues under the car because of heat? Any input is appreciated! Thanks guys.
Old Jun 9, 2015 | 03:06 PM
eLiT3_Z51's Avatar
eLiT3_Z51
Cruising
Anyone?
Old Jun 9, 2015 | 03:29 PM
Kracka's Avatar
Kracka
Yes, you'll trigger some codes with the valves unplugged. It won't really hurt anything though, just reset the codes once everything is plugged back in.
I'd suggest a ceramic coating rather than powdercoating due to the heat exposure. There is a wide variety of 1600F ceramic coating colors available; decent selection for 2000F coatings too.
Old Jun 9, 2015 | 05:08 PM
eLiT3_Z51's Avatar
eLiT3_Z51
Cruising
Ok cool. Thank you for the reply! As for the ceramic, I will definitely look into that! I was going to use a high temp powder good for up to 1200f.
Old Jun 9, 2015 | 05:12 PM
SharkGrayStingray's Avatar
SharkGrayStingray
just making sure you know you still have to remove the lower rear bumper cause the tips are attached all the way up to the xpipe
Old Jun 9, 2015 | 06:16 PM
eLiT3_Z51's Avatar
eLiT3_Z51
Cruising
Yes sir. I appreciate the heads up. I actually saw another thread on here with a diy
To Exhaust question
