Question: How to bypass 15 min audio timer?
Old Jun 15, 2015 | 07:51 PM
(Lucy)'s Avatar
(Lucy)
Account disabled by request Dec 2015
Default Question: How to bypass 15 min audio timer?
I understand that the C7 does drain battery power, and I have a resolution for that problem. My question is how can I bypass the 15 min timer for the audio for the Bose Infosytem that the BCM controls? From the wiring diagram I was able to see from the dealership, both the infosystem and amplifier go threw the BCM. Any answers!!
Thanks for your help!!
Old Jun 15, 2015 | 07:56 PM
Theta's Avatar
Theta
St. Jude Donor '14-'15
As of now, there is still no direct BCM communication available to modify those parameters.
You'd also have to deal with the global battery off timer, as you mentioned. The power-saving feature would most likely need to be disabled entirely, unless by chance the table actually had a delay parameter.
With MDIs and the global platform (GDS2/SPS) taking over, it's becoming increasingly more difficult, expensive, and time consuming to get a foothold into these BCMs.
The best that can be done at the moment are single-subsystem injections, but I know of nothing that could properly do what you're wanting.
