Revert procedures after track day
The problem is, do I need to spend the same money to revert all those changes after the track day? And before next track day, I need to do this again??
"After driving your Corvette Stingray (with the Z51 Performance Package) on the track, it is important to return the vehicle
back to the original factory settings with the proper fluids before normal street driving.
•Remove the brake rotor cooling rings
•Return the tire pressure settings to factory
(see the Tire and Loading Information label located below the door latch with the door open)
•Return the wheel alignment settings to factory
•Replace oil (use only engine oil licensed to the dexos1 specification of the proper SAE viscosity grade)
•Replace brake fluid (DOT3 Hydraulic Brake Fluid)
•Replace rear axle fluid (Dexron® LS Gear Oil)
•Rotate the Driver Mode Selector out of Track mode
For full details and information, see the vehicle Owner’s Manual."
Do I have to do all these when driving on the street? I mean, racing fluids are not cheap
Track days do have a cost and wear on your car's components; however I do not think that all the steps are needed for practical daily use in between days.
If you do not plan on any more track days in the future, then returning to stock trim makes sense.
Here's my thoughts:
Tire pressure - yes.
No brainer and no skills needed, better fuel economy and tire wear
Brake fluid - no
DOT 4 is not too much (maybe change if cold wether driving) or dirty after track days
Engine oil - no
15W/50 is thick like diesel oil, allow longer warm up before driving
Brake cooling rings - yes
Removed easily and not needed for daily use
Alignment - no
But expect faster wear on tires and reduced drivability as car will catch road grooves more. With tire wear the cost of re-aligning the car is offset with tire wear expenses
Rear axle fluid - no
Don't think the change is needed
Track mode - yes
Nannies are good for street use
Most of these take little to no mechanical skills are are just general care to revert to daily street use.
Just my thoghts....
I would at least invest in some track brake pads. Plus be aware-your calipers WILL change color, if you are using your brakes to the full extent.
Here's my thoughts:
Brake fluid - no
Engine oil - no
Alignment - no
Track mode - yes
Just my thoghts....
I live in SF bay area, so we don't actually have "cold weather" here
Here is what I think is required and not required, but GM's opinion might be different:
Not required. Might only cause some slight rusting of the rings. Mine have been on since spring 2014 and no issues
Required for proper handling
Required if you do a lot of street driving between events to minimize tire wear. Not required if you don't drive a whole lot on the street. I have mine set to track alignment at all times. This causes car to dart from side to side a little on cambered pavement. Not an issue for me, as tire wear on track is incredibly higher than on the road.
Not required if you don't drive in cold climates. Required if you start the car in cold weather. I just leave the 15W50 in all summer.
Not required. Just leave in the racing brake fluid like Castrol SRF and replace every 18 months at a minimum.
Required after first track day per the 2015 manual. Then replace after every 24 hours of track time. My fluid after 1 track day and about 3000 miles was dark and full of silvery material. Looked terrible. I would absolutely change it and not drive car on track until 1500 miles have elapsed per the manual.
Use mode you like
Use mode you like
