Base C7 sway bar upgrade installation question
Old Jun 21, 2015 | 08:40 AM
dckotwicki's Avatar
dckotwicki
Default Base C7 sway bar upgrade installation question
I received the Z51 sway bar upgrade kit from Cultrag.com. I have a question about the replacement rubber bushings (2 per bar). Front and rear look the same except that they accommodate different size bars.
Since the rear does not have a sway bar, it comes with the 2 clamps to secure the bar. the clamps have a recessed cavity on the inside to accommodate the rubber bushing that have a similar outward shape.
If I push the clamp onto the rubber bushing while NOT installed on the bar, the clamp and the ring fit perfectly. Once I install the bushing onto the bar, it seems like the I D of the rubber bushing is not large enough to accommodate the clamp. there is about a 1/8 inch gap at the seam.
It should be noted that the front and back bushings fit on their respective bars the same way. I don't have them backwards.
My question is this... Once I have everything in place and am ready to tighten everything up, will the tightening process cause the bushings to slide ( with lubrication ) into the clamp cavity and the seam to come together and fit the way it should causing me to live happily ever after???
Old Jun 21, 2015 | 09:56 AM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Yes they should button up nicely. Make sure to torque the bolts to spec as they are considered only one time use!!
