Any one swap to a LT4 map sensor?
Old Jul 3, 2015 | 02:40 PM
T/A KID's Avatar
T/A KID
Default Any one swap to a LT4 map sensor?
The LT1 Map sensor appears to measure up to around 2 lbs of boost (118KPA), anyone swap and LT4 3 Bar Map sensor in your boost C7 yet?
It appears the sensor will swap over, and the map sensor Linear and offset need adjusted as well.
http://paceperformance.com/i-2045265...t4-engine.html
I'm going to SD/MAF tune my new Ti A&A Kit I just ordered
Old Jul 3, 2015 | 10:35 PM
Cordes Performance Racing's Avatar
Supporting Vendor
we use the ls9 map sensor works well. Nice move on doing the TI head unit. That little S-trim is to small for a 6.2
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
Old Jul 4, 2015 | 12:29 AM
T/A KID's Avatar
T/A KID
Thanks Joe, I thought about doing the YSI, but unless your making 800rwhp or more it's not needed. For my goals this blower will be perfect.
Good to know the ls9 works. I'm going to use the lt4 when I boost it
Old Jul 6, 2015 | 10:34 PM
T/A KID's Avatar
T/A KID
Joe is the ls9 plug in play? No splicing or fitment issues?
Old Jul 6, 2015 | 10:55 PM
Supporting Vendor
direct swap, just have to adjust the tune for it.
Old Jul 6, 2015 | 11:08 PM
T/A KID's Avatar
T/A KID
Thanks you
Old Jul 7, 2015 | 09:14 AM
sycraft's Avatar
sycraft
Would there be any benefit to a NA car?
Old Jul 7, 2015 | 09:45 AM
Motohead279's Avatar
Motohead279
I'm having a YSI installed next week upgrading from te 1500. How would the LT4 map sensor help?
Old Jul 7, 2015 | 10:06 AM
T/A KID's Avatar
T/A KID
No benefit in a NA application, the factory map is fine.
The ls9 and LT4 map sensors are 3 bar and can read boost (higher than the factory 118kpa map)
Old Feb 24, 2016 | 10:17 AM
blown81bu's Avatar
blown81bu
55567257 blue label map is what i got with my iat breakout for my c7...
Does not sound right
To Any one swap to a LT4 map sensor?
