Z51 tow hook grill snap out
Old Jul 12, 2015 | 06:42 PM
Skylane765's Avatar
Skylane765
Supporting Vendor
Default Z51 tow hook grill snap out
I want to let the Z51 guys know that the 2x6 inch section of grill snap's out to insert our front tow hook, unlike the ZO6 grill does not snap out.
Old Jul 12, 2015 | 11:43 PM
ap6954's Avatar
ap6954
That is correct. I don't think you can use any hook on the z51 without taking this out, or cutting up the grill
Old Jul 13, 2015 | 01:37 PM
COL Dave L's Avatar
COL Dave L
Is there a fitting to accept a tow hook behind the Z51 grill?
Old Jul 13, 2015 | 09:42 PM
Skylane765's Avatar
Skylane765
Supporting Vendor
Thanks for the pic, yes most Z51 have the receivers, some early ones do not. We make receivers for all C7 corvettes. No tow hook will fit on the front of a Z51 unless you remove insert.
Old Jul 14, 2015 | 01:09 AM
Magister Ludi's Avatar
Magister Ludi
Well... Actually mine fits just fine in my 2014 with the grill insert in place.
Old Jul 14, 2015 | 07:40 PM
ap6954's Avatar
ap6954
Not sure how yours fit. Looks like the same hook I have from Phoenix and without seriously scratching up the insert to get the threads to push through it ain't fitting. You must have got an insert with loose tolerances! 😄
Old Jul 14, 2015 | 07:54 PM
Magister Ludi
Interesting. Guess I just lucked out.
Old Jul 20, 2015 | 10:59 AM
Skylane765's Avatar
Skylane765
Supporting Vendor
Not sure how yours fit. Looks like the same hook I have from Phoenix and without seriously scratching up the insert to get the threads to push through it ain't fitting. You must have got an insert with loose tolerances! ��
Just pull the plastic insert out by hand. Our tow hooks thread in to the receiver. I can see the pic, his insert is not in place. It has been pulled out. The tow hook will not go though the Z51 grill. He may not know he is missing the grill insert!
Old Jun 14, 2016 | 03:35 PM
dfettero's Avatar
dfettero
My front grille tow hook access panel just fell out somewhere. Need to buy replacement.
Old Oct 3, 2017 | 04:01 PM
DTcoltSAA's Avatar
DTcoltSAA
7th Gear
My access panel snaps in and out. the tow hook fit fine with the panel in place.
To Z51 tow hook grill snap out
