Lift pucks
Old Jul 15, 2015 | 01:26 PM
MYblu69's Avatar
MYblu69
Default Lift pucks
I have a set of lift pucks from my C6, will they fit my C7 also? Tks!!
Old Jul 15, 2015 | 04:42 PM
Theta's Avatar
Theta
St. Jude Donor '14-'15
They will work, but some 'leave-in' types were not staying put.
The normal puck and hoop idea still works great, though.
Old Jul 15, 2015 | 11:48 PM
owc6's Avatar
owc6
The aluminum jacking inserts from a steel frame C6 won't fit; the necks aren't long enough. The aluminum frame on the car is thicker. I was able to keep my Z06 pucks and they work just fine, but the ones from my '05 don't fit at all.
Old Jul 16, 2015 | 08:55 AM
MYblu69's Avatar
MYblu69
Where can I get pucks for my C7?
Old Jul 16, 2015 | 08:58 AM
Sir Nuke's Avatar
Sir Nuke
Southern Car Parts.....they have both the leave in style, and the billet type.
http://www.southerncarparts.com/corv...ks-p-5762.html
http://www.southerncarparts.com/corv...ks-p-6296.html
Old Jul 16, 2015 | 09:30 AM
thebishman's Avatar
thebishman
I use the leave in style plastic pucks from SCP and they've been great. Highly recommended.
Bish
Old Jul 16, 2015 | 09:49 AM
MYblu69's Avatar
MYblu69
Thanks all, I just ordered a set of the plastic "leave in" ones from Southern car parts.
Old Jul 16, 2015 | 03:24 PM
iclick's Avatar
iclick
I transferred the SCP stay-ins from my C6 to the C7 and they fit fine, though fit a bit tighter on the C7. They were quite loose on the C6, reportedly to allow water to be released from the frame, but I think there's enough looseness on the C7 for a water escape.
Old Jul 16, 2015 | 03:27 PM
iclick's Avatar
iclick
I transferred the stay-ins from my C6 to the C7 and they fit fine, though a bit tighter on the C7. They were quite loose on the C6, reportedly to allow water to be released from the frame, but I think there's enough looseness on the C7 for a water escape.
Has anyone used these pucks on the front and rear jacking areas? They seem to have two holes on each end to accommodate pucks.
To Lift pucks
