Another quick fueling thread...
Old Jul 30, 2015 | 03:32 PM
RideZX6R's Avatar
RideZX6R
Default Another quick fueling thread...
Basically wondering if the C7 coupe/non-Z06 fuel system will need any upgrades to run E85 and a 150-175 wet nitrous shot.
Figuring the following mods...
-E85 FFS
-Headers/catless x-pipe
-Ported Intake and TB
-Aftermarket Intake
-Tune
-175 shot
Assuming cam is stock and everything in the fuel system is too, will this work? Or will I need a Z06 pump or something else?
Thanks for the help!
Old Jul 30, 2015 | 03:48 PM
Higgs Boson's Avatar
Higgs Boson
you will be fine on fuel with a wet shot. a wet shot gets fuel before the high pressure system and there is plenty there for what you're doing.
a dry shot, you may have an issue. keep in mind you will need to use different jets on E85 than you will for E0/E10 to get the same power/AR ratio.
Old Jul 30, 2015 | 04:42 PM
RideZX6R's Avatar
RideZX6R
Awesome
Indeed, would prefer wet shot and yeah I know that E10 (we don't have E0 around here - that I know of anyway) jetting would be different. Would likely run it on E85 only and get all the power I can
Thanks mang!
Any special LT1/DFI-Specific tricks on nitrous for these cars?
To Another quick fueling thread...
