ARH Headers Primary Size..
Old Aug 6, 2015 | 12:56 PM
John Micheal Henry's Avatar
John Micheal Henry
Default ARH Headers Primary Size..
I'm having ARH headers with 1 3/4" primaries, cats, xpipe, and aFe CAI installed and tuned. My question is should I have the 1 7/8" primary size header installed. My tuner, installer said the 1 3/4" will support up to @700 hp.. I can't find any dyno results on long tube 1 3/4" headers. Thanks for your time and replies..
Old Aug 6, 2015 | 03:15 PM
ilivas's Avatar
ilivas
I would certainly go with the larger if it's not much of an inconvenience.
Old Aug 6, 2015 | 06:04 PM
MikeLsx's Avatar
MikeLsx
i have always gone with 1 7/8. Works great with just headers, or cam + blower.
Old Aug 7, 2015 | 10:18 AM
10mm_'s Avatar
10mm_
St. Jude Donor '15
It depends on your future mods, if you plan to only do headers and intake then 1 3/4" will have great power/tq down low and good mid range. If you plan to do heads/cam or blower down the road then the 1 7/8" will shine in that combo.
I went 1 3/4" because most of the time my car is in the low to mid range rpm, and I don't plan to do any big engine mods. I called ARH and they specifically said to use 1 3/4" if I don't plan to do a blower or heads/cam etc.
Old Aug 7, 2015 | 10:56 AM
SquatchMachining's Avatar
SquatchMachining
I have made over 1000whp through cheap *** texas speed 1.75" primary headers and that was 5+ years ago. People get really hung up on this header thing. I run 2" primariy ARH units now on a couple different cars because at that level you need that most flow you can get, but the bottom line is that they will indeed be fine for 90% of the people that buy them.
Old Aug 7, 2015 | 02:26 PM
longboy4's Avatar
longboy4
Like 10mm says here. How you use the car and margin for future modification. If its a header only with maybe a CAI install then or in the future....the 1-3/4 is the tried and true experiance. Going to cam later on......1-7/8. Learn your exhaust extraction funamentals. Bigger, larger, more..... seldom results in best when you first open the hood for your moding start.
Old Aug 7, 2015 | 02:37 PM
John Micheal Henry
Thanks for all your replies, I may have made a mistake. Ordered ARH 1 7/8" with cats and xpipe. Hope it works out with the aFe CAI and tune. I'll let you know the results in a couple weeks. Hope for 450hp/450tq at the wheels.. 2014 Z51/ M7
Old Aug 7, 2015 | 05:42 PM
thrilled's Avatar
thrilled
I have heard that just doing light stuff ,headers,COA,tune if you then go with 1+3/4 you'll
Have more torque at lower RPM's.Don't know if this is true.
Old Aug 7, 2015 | 07:10 PM
ilivas's Avatar
ilivas
I'm running 1 7/8s. Low end torque is still great, it's still a big v8.
Old Aug 8, 2015 | 07:44 AM
RottenII's Avatar
RottenII
I have the ARH LT's with AFE and tune and the car runs great. I was having the same dilemma when I ordered and decided to go with the 1 7/8 "just in case" and I'm glad I did. I was happy with just headers and tune for about a month. My ECS kit shipped yesterday.
Old Aug 8, 2015 | 10:06 AM
John Micheal Henry
RottenII, Man that's good to here. This is the beginning of my mods. I'm planning on going with a ECSC or A&A kit later. With your tune what was the RWHP/ TQ on your car? Thanks again for your time and reply. John
Old Aug 8, 2015 | 10:55 AM
RottenII's Avatar
RottenII
My tuning was done on a Mustang dyno so my numbers were 385/391 stock(just AFE) and 408/434 with headers/AFE and tune.
Old Aug 8, 2015 | 12:28 PM
John Micheal Henry
RottenII, Do you have an automatic transmission? Thanks again..
Old Aug 8, 2015 | 12:46 PM
RottenII's Avatar
RottenII
Originally Posted by john micheal henry
rottenii, do you have an automatic transmission? Thanks again..
'14 z51 m7
Old Aug 9, 2015 | 07:41 AM
marcouvo's Avatar
marcouvo
Normally, would go with 1-3/4", unless you're talking real high HP. But guys here post that these cars are different because of the DI and VVT.
And for a centrifugal blower car, the smaller header tube size will force the boost to come on sooner, from what I understand. That would be a good thing for a stock displacement motor. For a stroker, not so much.
Old Aug 9, 2015 | 01:15 PM
10mm_'s Avatar
10mm_
St. Jude Donor '15
A more free flowing exhaust will make more power even at less boost. Restricting your exhaust to make boost sooner is not going to be as fast as less boost less exhaust restriction.
Old Aug 9, 2015 | 03:08 PM
John Micheal Henry
10mm, Did you go with Texas Speed or ARH?
Old Aug 9, 2015 | 03:09 PM
10mm_'s Avatar
10mm_
St. Jude Donor '15
I went with ARH midlength actually. I wanted to keep the rear cats to try to help cut down the smell, and I'll pass visual state inspections.
Since I don't plan on engine mods I think these headers will be great.
To ARH Headers Primary Size..
