5th Gear Issue ?
Old Aug 11, 2015 | 10:25 AM
JPK_NJ's Avatar
JPK_NJ
Default 5th Gear Issue ?
2014 M7 / 6k miles. Earlier in the year I had GM align my shifter as it was occasionally popping out of second. Everything seemed pretty good for a while. Now I'm noticing some slight "crunch" when shifting into the 5th gear gate. No other gears feel this way and it's only the shifter box that feels odd. The car mechanically shifts fine, no issues there. Any idea what this could be?? FYI - car is not tracked but aggressively driven on weekends
Old Aug 13, 2015 | 11:35 AM
JPK_NJ's Avatar
JPK_NJ
anyone???
Old Aug 13, 2015 | 01:36 PM
REDBULLIT's Avatar
REDBULLIT
Sounds like you're having synchronizer issues.
Old Aug 13, 2015 | 04:02 PM
JPK_NJ's Avatar
JPK_NJ
With only 6K miles?? There really isn't any grinding noise when shifting, just the gearbox feeling slightly crunchy at the end of the shift movement. Should I just drive until it gets worse or try to explain / convince the dealership it might be an issue?
To 5th Gear Issue ?
