Engine light flashing
Old Aug 23, 2015 | 10:02 AM
ronv327's Avatar
ronv327
Default Engine light flashing
Yesterday, while out on a ride, was leaving a shopping center...after stopping for a quick bite. shut off traction control (in case I felt froggy & wanted to make some tire noise ) the light turned green & I turned left .not too hard (traffic) the check engine started flashing, the service rear axle light came on, the service stabiltrac light came on & the motor started skipping! After checking gauges, I limped it home . Plugged the scan tool in & had a cyl 5 misfire code. Popped the hood & checked the wires & found the #5 plug wire just barely hanging on the coil ( the plastic cover was keeping it from falling out) plugged it back in , cleared the misfire code & all seems well ...so far . Took it for a 3 mile drive . No lights on . we'll see on the next long trip
Old Aug 23, 2015 | 11:08 AM
NSC5's Avatar
NSC5
There have been a lot of reports of loose plug wires, something all of us should probably check after delivery since I doubt if they are working loose by themselves.
The flashing CEL is for a misfire and the stabiltrac and service axle lights come on with this so I am confident your found your only issue.
Old Aug 23, 2015 | 04:26 PM
ronv327's Avatar
ronv327
Thanks . That's what I was hoping for, but wasn't sure. Ck'd them all just to be sure...there doesn't seem to have much of a positive locking system.
Old Aug 23, 2015 | 11:22 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Glad it was something simple----
A misfire whether real or false will make the T/C and Stabilitrac show warnings-
A misfire trumps the timing tables in your ECM and both the T/C and Stabilitrac use timing in controlling TQ management---
-Also if your car is an automatic a misfire will prevent the converter from locking--
Old Aug 24, 2015 | 11:55 AM
ronv327's Avatar
ronv327
Yeah me too...panicked a little 'cause I had just filled it with fuel @ 15 mi. Before. 😱..but all is well , thanks
To Engine light flashing
