Spring Change For 2015 Z51
Old Sep 4, 2015 | 09:56 PM
B-STOCK's Avatar
B-STOCK
St. Jude Donor '14-'15, '17, '19
Default Spring Change For 2015 Z51
I purchased the Z51 package b/c I wanted the mag ride control and it was only available with the Z51 in 2015. My wife thinks the ride is rough and my aching old bones do too. Could I change the springs to base springs and soften the ride up or will that screw up the entire package?
Old Sep 4, 2015 | 10:02 PM
juanvaldez's Avatar
juanvaldez
Trade it for a Cadilac.
Old Sep 4, 2015 | 10:04 PM
Higgs Boson's Avatar
Higgs Boson
It's a Corvette. America's Sports Car.
The only changes it needs make it stiffer, louder, and smellier.
Old Sep 5, 2015 | 12:26 AM
B-STOCK's Avatar
B-STOCK
I already have a Caddy. These answers do nothing to answer my question. I bet you guys track your cars weekly right. Also are you all knocking the base suspension car?
Old Sep 5, 2015 | 12:33 AM
5thGear's Avatar
5thGear
Does it feel better in touring mode?
There is no doubt that the track and sport mode are stiff. Springs alone might not be the solution. Most of aftermarket springs and coilovers are built for track performance. Check with AFE as they might be able to assist you.
Old Sep 5, 2015 | 12:39 AM
B-STOCK's Avatar
B-STOCK
It's livable in tour mode. I was thinking perhaps I could swap out the springs of a non Z51 car for mine if they are interchangeable.
Old Sep 5, 2015 | 09:00 AM
sycraft's Avatar
sycraft
you could try removing the rear sway and see if that helps
Old Sep 5, 2015 | 09:29 AM
Higgs Boson
I had the base suspension, it rode like sht. I put Z51 shocks and sways on and it helped but I wanted more. So I sold the shocks and sways and threw away the leaf springs and put in AFE/Pfadt coilovers and sways and now it is very nice. The coilovers can be very stiff (road course) or softer than stock (drag strip) or in between (street). The sways are also adjustable. So.....yes, I am knocking the base suspension; it's for cruisers and waxers. I do believe the base springs are softer than Z51, btw.
No, I don't go to the track every weekend, but I do live in the hill country with some great twisties.
Old Sep 5, 2015 | 12:07 PM
axr6's Avatar
axr6
I also started with the base model. Not being happy with the softness of the suspension I added the Z51 shocks and the Z51 Mag Ride sway bars (31mm rear bar).
The car handles much better while I still find the ride very good over good surfaces and acceptable over rough pavement.
I do think (but no facts on this) that the base springs are softer, soft enough to make my car bottom at the driver's rear corner when I hit some dips over my local secondary roads. The bottoming is to the rear of the wheel liner, not to the top. Stiffer springs would likely prevent that.
Old Sep 5, 2015 | 12:23 PM
Higgs Boson
interestingly, on my car the front of the rear passenger wheel liner (bulge in the liner around the evap canister) is where i get contact under extreme compression.
Old Sep 5, 2015 | 12:32 PM
crazybiker51's Avatar
crazybiker51
I'll trade you for my base springs
Old Sep 5, 2015 | 12:34 PM
axr6's Avatar
axr6
That is interesting. On my car there is plenty of room in front of the rear wheels. The bottoming is against the bulge at the rear of the tire that is created by the small inside storage compartment at the driver side. My liner is almost worn through at this point. As I looked at a possible solution, I do not see any, short of cutting away the wall of that storage compartment.
I suspect there are some installation variations and tolerances that make the difference car-to-car.
Old Sep 5, 2015 | 12:38 PM
Higgs Boson
there must be a lot, I wish my rear wheels sat a little further back! makes me wonder if lowering it makes the rear sit down at an angle rather than straight down. mine sits pretty low, maybe thats what's up.....making me think.
Old Sep 5, 2015 | 12:51 PM
axr6's Avatar
axr6
Mine is lowered all the way on stock bolts. The total lowering amounted to 0.5" but, the touching occurs, what appears, between 1 - 3" of suspension travel. I also suspect that bushings in the long rear A-arms have enough "give" to allow for a horizontal deflection upon hitting a sudden dip in the road. If I put a vertical straigth ruler against the back of the rear tire it tells me that if the rear wheel compressed in a totally vertical manner, no contact would be made. The rear wheel must actually deflect backwards 1/4-1/2" for the contact.
Old Sep 5, 2015 | 01:05 PM
Higgs Boson
What is your measurement from the top of the fender to the ground? My rears are at 27", thinking of moving them up to 28. My fronts are 26, moving them up to 27. My rear tires are 27, fronts are 26.3.
Old Sep 5, 2015 | 01:25 PM
meyerweb's Avatar
meyerweb
Typical of this forum. People insult the OP, answer questions he didn't ask, and fail to answer the one he did, then go completely off topic.
To the OP, there was a thread on here recently from someone who planned to change his base (I think) springs to the Z06 ones. Search for "springs" or "sprint rate" and see if you can find it. I'm pretty sure all the springs are interchangeable in fit, but if that member has done the swap he should be able to verify that. Maybe he'd even sell you his base springs cheap.
Old Sep 5, 2015 | 01:36 PM
B-STOCK's Avatar
B-STOCK
If you were closer my friend.
To Spring Change For 2015 Z51
Old Sep 5, 2015 | 01:37 PM
B-STOCK's Avatar
B-STOCK
Thank you meyerweb You are 100% correct. When I was a teenager a straight axle Corvette was great. My 66 GTO had 427 ElCamio front springs and drag bags. If the headers were not open they had washers between the dump tubes and the caps to make my presence known. With 4:33s 75 MPH on the highway was a event. Not that I am 70 life changes and I am looking for a little more comfort. Still row my own and have the exhaust fuse pulled so I don't get the 1700 RPM hitch. Quieter than my C6 with duel mode but OK. I hate it when someone from a fair weather state with great roads criticizes the suspension choices of people from RI or MA that have the worst roads in the country. Off topic but when I bought my new C6 from a dealer in Georgia and drove it home to RI I thought the suspension was too soft till I hit DC. By the time I hit NJ & NY it rode like I put 15 extra pounds of pressure in the tires. Traveling though CT to RI I knew the suspension was firm enough for our roads and my age. Have a good holiday. Mike
Old Sep 5, 2015 | 02:35 PM
Higgs Boson
Americans sure have gotten thin skinned. Lots of crying and hurt feelings. No one insulted anyone, but we did answer his question:
1 vote for the same rate
2 votes for softer
270 votes for "I have no idea" based on thread views
and even a few recommendations on how to improve the situation
what else do you want? i am sure that if the info were available in a search this thread would not exist.
Old Sep 5, 2015 | 04:55 PM
EcoBrick Bob's Avatar
EcoBrick Bob
Dazed Confused & Verklemp
I don't think you will gain much as to softening the ride. Here's why...
My son has a 15 M7 Vert (base) with the Zf1 package ( 19"-20" tires, the same as Z51). I have a 15 Z51 A8 Coupe with MRC. I have driven both as has he. The ride is very similar when you compare my Z51MRC in "T" or "E" and his car. In fact, he thinks my car rides slightly softer in those settings.
So... even if this can be done, I'm not sure you would find a worthwhile difference.
For comparison, I have a TT Ford Flex withe Megan Coilovers. The softest setting ( of 31 choices) is more harsh on sharp ridges/bumps than our Vette. Harshest setting is much harder than the MRC. Surprisingly, when I have my 18" Michelin Pilot Super Sports mounted on that vehicle, it rides better than with the stock Goodyear 20". My wife hates the Flex, not because of the ride, but because of the loud exhaust system I have installed!
So.. you might consider getting rid of your run-flats which have VERY stiff sidewalls, and going with the Michelin Pilot Super Sport non-run flats in the stock Z51 sizes.
Or... trade in your wife...
