Paperwork states spray starts after 80% throttle response and stops below 80%. 3 short passing gear test runs seamed to work OK ?
C5-JIM
that just means it doesn't work below 80% throttle. do you let off each time to let the auto trans shift? most people don't. that means it is spraying through the shift.
the concern is not that it won't work, the concern is how long will the trans last.
Sounds like if your not concerned about money don't be concerned about the problem
Sorry but I am looking for tech support not opinions.
C5-JIM
We advise to use the window switch so that not to leave your trans. at the track. Have it cut off 100 RPM's before the shift, and after the shift you should be about 5800 RPM's and it will reactivate.
__________________
Worlds Quickest C8 Corvette 8.83@160MPH
FIRST C7 Corvette in the 7's & 9's
2019 ZR1 LT5 8.874 @ 155
Current C7 World Record Holder 7.55 @ 184 MPH
Quickest and Fastest GEN5 LT Powered Vehicle
LMR1200HP Supercharged C7 8.84 @ 160
LMR1200HP Twin Turbo C7 9.35@155mph-2014
2 TIME OUTLAW DRAG RADIAL LSX CHAMPION 2008/2010
9.47 ZR1 Corvette-2009 LATE MODEL RACECRAFT
713-466-9900
LateModelRacecraft.com
Too many PMs, please call or email instead, thanks!
