Parking brake
Old Sep 18, 2015 | 08:25 AM
duanepillar's Avatar
duanepillar
Default Parking brake
Hey,
I use my parking/e-brake every time I shut the car off. Good, bad, no difference? Whats your opinions?
Old Sep 18, 2015 | 10:32 AM
Flame Red's Avatar
Flame Red
The only thing I would recommend is NOT applying the parking brakes immediately after you wash the car. Sometimes the brakes seem to stick, and you have to seem to rock the car between R & D to free them up.
Other than that, I don't think it makes a lot of difference if you park level with an automatic. Of course if you are on an incline, parking brake is the rule!
Old Sep 18, 2015 | 11:27 AM
alienranch's Avatar
alienranch
^^ good advice ^^
I don't see the harm, but probably just an extra step if you have an auto. For a manual, I would do this every time.
Old Sep 18, 2015 | 11:35 AM
meyerweb's Avatar
meyerweb
Always have, always will. Manual and auto.
Old Sep 18, 2015 | 09:16 PM
mendeldl's Avatar
mendeldl
I found the first time I parked in my very steep drive that the engine compression alone is not enough to keep the car stationary. Came out after parking to find it backed out of the drive and resting against the curb. Using the e-brake diligently now...
I don't see any issue in using it, but do agree with the comment on being careful after washes.
Old Sep 18, 2015 | 09:49 PM
bob guzzy's Avatar
bob guzzy
You have to use it if you want the memory seat to function.
I need my seat all the way back to swing my bad leg into the car so its a must to use the ebrake.
Old Sep 18, 2015 | 09:55 PM
Higgs Boson's Avatar
Higgs Boson
I use the parking brake in all cars even on perfectly flat ground and an automatic transmission.
Old Sep 18, 2015 | 11:37 PM
C7/Z06 Man's Avatar
C7/Z06 Man
Auto= no
Stick= yes, and with a stick don't forget to turn your wheels into the curb just in case the parking brake does not hold.
Old Sep 18, 2015 | 11:41 PM
owc6's Avatar
owc6
Why is this a new and confusing topic?
Use it the same as the last 50 years. The only difference is that it is "electronic" and will disengage when you apply power .
Old Sep 19, 2015 | 04:00 PM
meyerweb's Avatar
meyerweb
Doesn't the parking brake actuate a separate, small drum brake, rather than the disks? If so, whether the parking brake is applied or not won't make any difference to the pads sticking to the disks.
Old Sep 19, 2015 | 09:51 PM
mendeldl's Avatar
mendeldl
Yeah, good point, I think that is correct and realized that today when I was testing a theory on Hill Assist.
Old Aug 20, 2021 | 10:31 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Hmm never use the parking brake for the year I have had my C8. Memory seats work fine!
PS We’re flat as a pancake in NE SC so no need. Funny up to the C8 only had standard shifts for DDs and never kept in gear (as is also recommended) only used the parking brake! Old habit from my 1941 Ford I had in 1960 and later standard shifts as IF someone tapped your bumper (yep had real bumper back in the day) could hurt the trans!
To Parking brake
