HELP! Broken Bumper Tabs :/
Old Sep 20, 2015 | 01:47 AM
marcussoori's Avatar
marcussoori
Default HELP! Broken Bumper Tabs :/
Broke both of the far outside front bumper tabs (nearest to inside edges of headlights) during bumper removal for Z06 grille install.
Now have the "stick-up corners" issue (but with a different cause than everyone else?).
The broken tabs are still in their correct places under the bumper corners.
I'm thinking of applying super glue to the top edges of the broken bumper tab pieces, then pressing down on the corners in the hope that the tab and bumper on each side will realign. Another option may be using double sided tape to hold down the corners? Otherwise...
Any idea of how to fix this?
Anyone else with this problem?
Old Sep 20, 2015 | 10:06 AM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
I'd look to see if there is anything you can hook to inside the corner of the bumper. If so you can pull the corner in by tying with a zip tie..
Old Sep 20, 2015 | 10:28 AM
mustclime's Avatar
mustclime
Amazon.com: 3M 04747 Duramix Super Fast Adhesive - 50 ml: Automotive Amazon.com: 3M 04747 Duramix Super Fast Adhesive - 50 ml: Automotive
hope that helps
Old Sep 21, 2015 | 09:37 AM
stab1991's Avatar
stab1991
Just order a new part.
Old Sep 21, 2015 | 03:01 PM
Bucknut2006's Avatar
Bucknut2006
Completely new bumper?
Old Sep 21, 2015 | 03:07 PM
stab1991's Avatar
stab1991
No, look up the bumper schematic on cultrags site, I'm assuming you mean the plastic tabs that the bumper cover male ends push into. The clip strip is a replaceable part. Unless u broke the ends off the bumper cover itself, then sorry, I have no help for you.
Old Sep 21, 2015 | 04:50 PM
Bucknut2006
Not my car so I can't say for sure, but the tabs on the bumper are more likely to break than the clip itself which is metal. I had my bumper off when I did my own Z06 grill swap so I'm familiar with the actual pieces.
Old Sep 21, 2015 | 05:05 PM
stab1991's Avatar
stab1991
The tabs on the sides of the headlights are plastic.... The ones towards the wheelwell
Old Oct 1, 2015 | 08:22 PM
mustclime's Avatar
mustclime
Don't know if you found anything...I did see this...
http://www.parts123.com/corvettecent...50V&ukey=40050
Old Oct 22, 2015 | 01:17 PM
marcussoori
FIXED...with liquid (NOT gel) super glue.
Old Oct 22, 2015 | 01:55 PM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
Nice, good job!
Old Oct 22, 2015 | 03:21 PM
Elite275's Avatar
Elite275
Excellent...glad the simple fix worked out!
Old Oct 25, 2015 | 11:24 PM
SharkGrayStingray's Avatar
SharkGrayStingray
if the broken tabs are what caused the lift in the corners, than the glue might eventually fail. If that's the case, i just wanted to tell you what fixed my corners to lift. after my Z06 grille install both my corners were raised a decent amount. I played around for a while to try to fix it to no avail. I realized i would just have to bite the bullet and remove the bumper and adjust it again. I did that and while reattaching the screws, i had to apply downward pressure on the whole bumper while tightening the screws. It's perfect now.
Old Oct 26, 2015 | 12:38 AM
REDBULLIT's Avatar
REDBULLIT
Which screws are you talking about? the ones on the tab?
Old Oct 26, 2015 | 12:41 AM
SharkGrayStingray
all the screws that hold the bumper in place. i didn't touch the screws on the bracket that the tabs fit into.
To HELP! Broken Bumper Tabs :/
