Help...need caliper bolt part numbers-Z51
Old Sep 21, 2015 | 11:41 PM
NC94Vette's Avatar
NC94Vette
Default Help...need caliper bolt part numbers-Z51
I have looked online at various sites and inside the forum.
Here is what I have found for Z51 Brake Parts:
Brake rotor bolts: 11570339 (small bolt holding the rotor to the hub)
Front Brake Caliper Bolts: 11611085
Rear Brake Caliper Bolts: ?????
Brake Pins Front: 23454015
Brake Pins Rear: 22968938
Can someone please confirm what I have found and fill in the blank for the Rear Caliper Bolts?
Thanks much parts gurus.
Old Sep 28, 2015 | 06:45 PM
NC94Vette's Avatar
NC94Vette
To The Top .... Looking for Help
Old Oct 1, 2015 | 12:30 PM
bob guzzy's Avatar
bob guzzy
I am assuming you are looking for the bolts that hold the caliper to the bracket?
My guess the front and rear would be the same bolt, I would take a look at the heads of the bolts if they look to be the same size and the length looks close they would be the same part number, or you could run one front and one rear out and compare them.
You might be able to find grade 8 bolts the same size at Lowes or Home Depot that would work.
Old Oct 1, 2015 | 08:26 PM
NC94Vette's Avatar
NC94Vette
Default Not the same front and rear on C7
The C6 caliper bolts were the same on the front and rear ... with the same torque. The C7s are totally different. The back ones are way smaller and require far less torque. So different parts with different part numbers. Still looking for help with the rear bolt part number. Thanks!
Old Oct 1, 2015 | 08:40 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
We would certainly be happy to help you out with the bolts. Feel free to send us an email or give us a call.
Old Oct 3, 2015 | 03:26 PM
NC94Vette's Avatar
NC94Vette
Thanks Gene. PM me the part numbers and delivered price for two front and two rear caliper bolts. Zip code: 27513. Thanks!
Old Nov 30, 2015 | 08:28 AM
NC94Vette's Avatar
NC94Vette
Default Still Looking for the part Number ...
Hey everyone ... I am still looking for the part number for the rear caliper bolts.
Old Dec 12, 2015 | 11:57 AM
NC94Vette's Avatar
NC94Vette
Default Completed Part Number Information
Just in case someone searches for the complete information in the future, I have filled in the Rear Caliper Bolt part number. The rest were also confirmed.
Rear Brake Caliper Bolts: 11570091
Old Apr 3, 2016 | 02:21 PM
baron95's Avatar
baron95
Thank you so much for the info - I too was looking for the rear caliper bolt info.
Do you know what size socket is needed for the rear caliper bolts?
Old Jul 10, 2016 | 10:41 PM
NC94Vette's Avatar
NC94Vette
Sorry about the very slow response ... it is a 15 mm.
To Help...need caliper bolt part numbers-Z51
