C7 HVAC Blower Replacement
Old Oct 25, 2015 | 08:27 AM
HVLOCTY's Avatar
HVLOCTY
2nd Gear
Default C7 HVAC Blower Replacement
I need to replace the HVAC blower due to a mouse entering the system and leaving a foul mess causing the squirrel cage to freeze up burning out the blower motor. How do I access the blower assembly to remove and replace?
Old Oct 25, 2015 | 12:38 PM
bob guzzy's Avatar
bob guzzy
I would suggest you go to a chevy dealer and ask for a print out of the blower motor replacement procedure.
Then when you look at the actual job you will have an idea of what to do.
Unless someone here has a manual they can access to print you a page.
You might give Cultrag a try see if they have a blowup of the blower motor in the parts catalog.
Old Oct 25, 2015 | 09:20 PM
HVLOCTY's Avatar
HVLOCTY
2nd Gear
Thanks Bob, I will follow up with my Chevy dealer.....maybe more complicated than I want to tackle.
Old Nov 3, 2015 | 09:03 PM
meyerweb's Avatar
meyerweb
I can't answer the question, but given the way cars are assembled today I wouldn't be surprised if the entire dash has to come out.
Old Nov 4, 2015 | 10:41 AM
Flame Red's Avatar
Flame Red
For $20, you can access the on-line service manuals for 3 days: https://www.acdelcotds.com/acdelco/a...subscribeTo=gm
Use Internet Explorer, and download and install the SVG add on. Also install PDFCreator so when you print the documents, you can save them to a PDF for future reference.
To C7 HVAC Blower Replacement
